Yellow leather strap...
NapoleonDynamite
Post by NapoleonDynamite »
I'm after a 18mm leather yellow strap like the following for my wife's Mondaine. I ain't paying Mondaine prices though....
It'd be great to have a range with different colours, but I'm after this specific style.
Quick release would be good but not a deal breaker.
Any recommendations would be appreciated!
Thanks in advance! Image
Sent from my SM-G950F using Tapatalk
Re: Yellow leather strap...
How about these from AliExpress?
I think [mention]AndyS[/mention] may know of other options
https://m.aliexpress.com/item/32963172196.html
NapoleonDynamite
TheJohnP wrote:How about these from AliExpress?
Thanks! Great start. Look forward to anymore suggestions.
tommy_boy
Post by tommy_boy »
18 Euros plus shipping. 190 mm total length.
https://www.watch-band-center.com/watch ... LICK-.html
AndyS
Post by AndyS »
TheJohnP wrote: Wed Dec 25, 2019 11:39 pm How about these from AliExpress?
I think @AndyS may know of other options
I don't search for yellow 18mm bands very often :)
A quick search turned up some PU bands for really cheap and this for $10:
https://www.aliexpress.com/item/32815686309.html
I think that brand can also be found on Amazon for a little more sometimes.
OR, this for under $15 (note the coupon on the page):
https://www.aliexpress.com/item/4000118844138.html
Neither are quick release. BUT, you can buy the quick release spring bars and add them yourself if you want. I do it all the time with an xacto knife. Just take a strap that has quick release, mark where your hole needs to start and stop on the new band, insert either another spring bar or a finishing nail into the strap to stop you from cutting all the way through, then cut your two short ends of the hole. Then cut the top and bottom long cuts to connect the end cuts, and pull out the "hole" material. Insert a quick release spring bar into your newly cut hole, then work the short end over the retracted end of the spring bar.
Link
NapoleonDynamite
Thanks everyone! I'm going to give the Meyhofer ones a crack!
