Custom Watch Storage
So my wife and I recently started building out our walk in closet. We designed it at Ikea using the Pax system and we're also customizing it. I made built in shoe shelves for the wife and now I get to attempt to build custom watch storage. I highly recommend the Pax, we would have spent $10,000 for the same closet but custom. We spent well under $2,000 for the Ikea system.
I started with 2.5" by 1\2" poplar wood to make the box.
So far so good. My cuts were pretty darn good. I used wood glue and finishing nails to build it.
Next was the hard part... the actual watch storage. For this, I got 1.5" x 1/4" poplar. I used bar clamps to hold the pieces together and cut them together for consistency.
Next was making the slot cuts to combine the pieces. The slots needed to be 1/4" wide , but my compact saw blade was nowhere near that thick. So I marked 1/4" wide on the correct spots and made several passes.with the compact saw to get it an 1/4" wide. Then used a chisel to.even out the cuts. The cuts aren't perfect, but good enough. Wood fill is your friend.
Next was putting together the cuts. My cuts were pretty decent so they fit fairly snug. Some sections will need wood fill and then a coat of paint. Once together, I secured them to the box with finishing nails.
I then did wood fill to cover any areas with gaps. I didn't have too many gaps, but since I'm painting it I want to fill any imperfections.
Next step is tomorrow: painting it. This is the box in the shelf. I'm pretty stoked at how well it came out so far. I'm hoping to finish tomorrow, but I do still need a bunch of watch pillows. 48 to be exact. Anyone know of a good place to get inexpensive ones?
Re: Custom Watch Storage
This looks awesome. My wife and I did our closet last year with a lower end container store. My only regret is not doing something specifically for watches.
.38 a piece at AliExpress
https://aliexpress.com/item/4000288483618.html
15 pieces for $15 at Amazon
- AndroidIsAwesome
What I do for cheap pillows is 3" diameter foam pipe then just cut it to your width. Or if you can't find that size take two smaller ones, cut a slot in them and put one in the other
Have been considering doing this with a Pax. Great job, it looks fantastic. For cushions, Amazon or AliExpress have lots. Some options:Stretch44 wrote: ↑Sat Feb 15, 2020 9:42 pm So my wife and I recently started building out our walk in closet. We designed it at Ikea using the Pax system and we're also customizing it. I made built in shoe shelves for the wife and now I get to attempt to build custom watch storage. I highly recommend the Pax, we would have spent $10,000 for the same closet but custom. We spent well under $2,000 for the Ikea system.
I started with 2.5" by 1\4" poplar wood to make the box.
Next was the hard part... the actual watch storage. For this, I got 1.5" x 1/8" poplar. I used bar clamps to hold the pieces together and cut them together for consistency.
Next was making the slot cuts to combine the pieces. The slots needed to be 1/8" wide , but my compact saw blade was nowhere near that thick. So I marked 1/8" wide on the correct spots and made several passes.with the compact saw to get it an 1/8" wide. Then used a chisel to.even out the cuts. The cuts aren't perfect, but good enough. Wood fill is your friend.
Here $2.81 for 5:
https://www.aliexpress.com/item/4000149 ... hweb201603_
Other options at AliExpress: https://www.aliexpress.com/af/Watch%252 ... 5e20il0bvH
Here 10 for $9.88:
Here 20 for for $10.90:
Here 20 for $9.90:
Thanks for the tip, [mention]TheJohnP[/mention] and [mention]watchapalooza[/mention]. I ordered a bunch from Amazon. Hopefully they work out. If not, I'll try [mention]Androidisawesome[/mention]'s method.
Here it is painted with my cushions from other boxes. I'm pretty happy with it for being my first watch storage build.
That looks great! I think the cushions fit your aesthetic better than the pipe foam would. For me pipe foam is preferred as I look to build a vertical wall cabinet and for the configuration they hold better.Stretch44 wrote: ↑Sun Feb 16, 2020 5:12 pm Thanks for the tip, @TheJohnP and @watchapalooza. I ordered a bunch from Amazon. Hopefully they work out. If not, I'll try @Androidisawesome's method.
- Split-Time
This is great! Really well done and you should be proud. I see the MoT sticker in there, too .Stretch44 wrote: ↑Sun Feb 16, 2020 5:12 pm Thanks for the tip, @TheJohnP and @watchapalooza. I ordered a bunch from Amazon. Hopefully they work out. If not, I'll try @Androidisawesome's method.
- mplsabdullah
Awesome work [emoji106]
Sent from my SM-N975U1 using Tapatalk
Great looking box!
This is fantastic - very well done!
I have been considering something similar, but the issue of security has always given me pause (not to mention my limited DIY skills). I thought about trying to do it in metal, but that's obviously a lot more work and wouldn't have a display top.
Your project has me reconsidering!
Thanks! It was a fun project and relatively easy. If I had to do it over again I would have purchased cushions first to determine the size of each cubbie. I used the dimensions of my then current watch box thinking it'd be the same. The cushions I've found are either too wide or not wide enough. Here's a pic with the different cushions.baldrick wrote: ↑Sat May 02, 2020 1:22 am This is fantastic - very well done!
- whoagorgeous
It's filling up quick!
Yeah... a little too quick!
I love seeing watches I have modified in someone’s collection. I need to get back to making more of these though I always wonder if anyone wants them. Hopefully my next round is made from better base watches.
