I have a confession. I don't really like the bracelet on the Casio Oceanus. But I love the watch, so after one failed attempt to custom fit a rubber strap, I decided to accept it. Until today. I snagged a couple cheap leather NATOs from the recent Cheapest NATO Straps sale - brown and blue single pass - and cut slits in them to thread the bracelet pin. Here are the results.
As you can see, I forgot that the Oceanus actually has a 21mm lug width. Or maybe I overlooked that because these were low-risk prototypes. And the blue strap came in at 19mm anyway, so it looks even worse. And I didn't quite place the slits evenly from each edge. Even with all that overlooked, I'm not sure I like the look. It's growing on me.
Where I could use some help: The bracelet is normally set with a pin and collar, with the collars fitting into the bracelet. This is not an option with the NATO. The friction on the pin seems good enough, but I don't want to lose a pin. I considered 6mm spring bars, but don't have any on hand to test. Any suggestions?
Oceanus on a NATO
- Sussa
- Has thanked: 2520 times
- Been thanked: 4965 times
- Sporkboy
- Has thanked: 2570 times
- Been thanked: 5989 times
Re: Oceanus on a NATO
It actually looks pretty good. You can get an assortment of friction pins if need be. Of course I have those and a spring bar assortment...at work. I should have brought my watch toolbox with me, but there was no way to know what was to come.
Anyway, I will think about this as I have a Swatch that may need a similar treatment.
- Sussa
An interesting new discovery this morning. I've never received a radio signal update on this watch at home. I'm in the Boston area and assumed I was just slightly outside of the signal range because it has received a signal when traveling closer to Colorado. Today it's reporting a successful signal overnight. Could the bracelet have been interfering with the reception? If so, it's definitely staying on the NATO.
- MoT
- Site Admin
- Has thanked: 13431 times
- Been thanked: 30144 times
Could be. The metal in the bracelet just may be enough to attenuate the signal, especially in places outside the "normal" range of it.Sussa wrote: ↑Mon Apr 13, 2020 8:42 am An interesting new discovery this morning. I've never received a radio signal update on this watch at home. I'm in the Boston area and assumed I was just slightly outside of the signal range because it has received a signal when traveling closer to Colorado. Today it's reporting a successful signal overnight. Could the bracelet have been interfering with the reception? If so, it's definitely staying on the NATO.
