Recommend a deployant for a leather strap?
- Has thanked: 79 times
- Been thanked: 904 times
An in-coming strap is an odd size, 17mm width. Would a commonly available 18mm deployant fit OK without looking weird? Also, for this exercise gold is preferred. I'm seeing prices from about $11-$39, because I'm totally ignoring anything higher.
- cortman
- Has thanked: 10052 times
- Been thanked: 3892 times
Re: Recommend a deployant for a leather strap?
One of these came on a watch I bought used. I liked it enough that I messaged the guy I bought it from and asked him where he got it. Seems quite nice especially for the price.
Sent from my moto g(6) using Tapatalk
- Has thanked: 21228 times
- Been thanked: 23299 times
Unfortunately I don't have an actual recommendation for a deployant. However, I recommend that you don't make the same mistake I once made. Buying a deployant based on the strap width rather than the width that the strap tapers down to at the end.
- Has thanked: 21586 times
- Been thanked: 12443 times
This is good advice...more than one of us have made that mistake...yinzburgher wrote: ↑Wed Jan 16, 2019 1:19 am Unfortunately I don't have an actual recommendation for a deployant. However, I recommend that you don't make the same mistake I once made. Buying a deployant based on the strap width rather than the width that the strap tapers down to at the end.
I’ll wait until the strap comes in and measure it first. And for the price I’ll likely try that iStrap on Amazon, thanks.
- Has thanked: 554 times
- Been thanked: 114 times
Make sure to measure the thickness of the strap as well. The iStrap's max is 3.5mm. This pricier Hadley Roma will accommodate 5mm.deckeda wrote:I’ll wait until the strap comes in and measure it first. And for the price I’ll likely try that iStrap on Amazon, thanks.
https://www.holbensfinewatchbands.com/h ... lasp-gold/
- cheddar
- Has thanked: 929 times
- Been thanked: 1131 times
Figured I'd resurrect this old deployant / deployment clasp thread instead of starting a new one. Earlier this year I bought several of the iStrap clasps off Amazon, which appears to be what [mention]cortman[/mention] was referencing above, as I wanted them on my cordovan straps to help prevent wear. I've been very happy with them so far and would definitely recommend for $11. However, remember that wrist shape is very important with these types of clasps -- the back of my wrist is relatively flat, and there are places where the curve of this clasp fits it perfectly. Those with a rounder wrist may not have as good a fit.
