Cheap case back press
Elkins45
Post by Elkins45 »
https://www.harborfreight.com/watch-cas ... 91621.html
If you have a Harbor Freight in your are this might be a bargain should you need one. Having ruined two watches trying to replace the back I wish I had known this earlier. $13.99
Re: Cheap case back press
Elkins45 wrote: Wed Mar 10, 2021 7:00 pm https://www.harborfreight.com/watch-cas ... 91621.html
Great tip!
That's the very one I use, and it definitely comes in handy.
Miggyd87
Post by Miggyd87 »
I have the same..can attest...$13 well spent
recapt
Post by recapt »
For the uninitiated, these can also be used as a crystal press and bezel press. I’ve used my cheapo eBay version for all of those use cases with success.
And speaking of Harbor Freight, I have been kicking myself for not picking this up last time I was there:
