Vario watch box and strap organizer survey
Vario watches, who have successfully funded a Kickstarter for their Empire Art Deco watch, also makes travel accessories.
For instance, you can still pre-order, their latest watch travel case.
https://vario.sg/collections/watch-acce ... ravel-case
They are also looking to potentially make a watch box and a strap organizer.
With that, they've got a survey to gauge interest and consumer insights.
If you'd like to participate, you should be able to access the survey here:
https://docs.google.com/forms/d/e/1FAIp ... g/viewform
[img][/img]
[img][/img]
[img][/img]
Re: Vario watch box and strap organizer survey
Survey completed. I do need a better watch strap storage solution, but I do not think theirs is the one for me. I seek one with at least 8 compartments: one each for straps 12-14mm, 16mm, 17mm, 18mm, 19mm, 20mm, 22mm+, accessories like extra buckles. They must be large enough to accommodate 10 to 20 straps each. Here is what I use now, but its starting to fall apart:
[img]https://picr.me/i/2019/05/11/V2LrK8.jpg[/img]
