Paratrooper straps from Cheapest NATO Straps
Animal Mother
Has thanked: 81 times
Been thanked: 787 times
Re: Paratrooper straps from Cheapest NATO Straps
Post by Animal Mother »
larand wrote: Thu Jun 06, 2019 7:31 pm
larand wrote:Nobody has mentioned Watch Steward straps yet—I've ordered one for my Bertucci A-2T and will report back when it arrives. Looks like it might be a good solution for watches with fixed bars, and the Bertucci has enough space at the lugs that it should fit through them, hardware and all. Someone on WUS seems to have managed it.
Tap. Talk. Buy a watch. Repeat.
Well, that didn't work out. Despite what was claimed by someone on WUS, there's no way to cram it through the lugs of an A-2T. I suspected this might happen, so it'll probably end up on one of my other watches.
Meanwhile, back to square one with the Bertucci.
Edit: looks like I spoke too soon. Some determined fiddling, and voilà! It's a bit tricky to fasten, and I won't be swapping it anytime soon, but I do like the look.
My Watch Steward review here:
viewtopic.php?f=18&t=878
Has thanked: 21586 times
Been thanked: 12443 times
The replacement buckles arrived and they do solve the issues for me. The old one is on the left, the replacement on the right. As you can see the new ones have 4 slots, permitting the band to loop back through for more secure attachment. These stay securely in place without slipping....I am quite pleased.
NapoleonDynamite
Has thanked: 226 times
Been thanked: 628 times
Post by NapoleonDynamite »
watchpalooza wrote:The replacement buckles arrived and they do solve the issues for me. The old one is on the left, the replacement on the right. As you can see the new ones have 4 slots, permitting the band to loop back through for more secure attachment. These stay securely in place without slipping....I am quite pleased.
Nice! Which brand/site straps were these fixing again?
Sent from my SM-G950F using Tapatalk
NapoleonDynamite wrote: Sat Jun 22, 2019 4:25 am
^ See thread title
Has thanked: 2570 times
Been thanked: 5989 times
I take it that these were replacements provided by Sofie at CNS. If so, I will have to contact her about this as the strap is currently uncomfortable for me to wear due to where I have to put the buckle in order to keep the end from being loose. Looks like this would really help.
Sporkboy wrote: Sat Jun 22, 2019 7:07 am
Yes, these were the replacements Sophie sent. Would definitely suggest to contact her.
ILiveOnWacker
Has thanked: 18 times
Been thanked: 208 times
Post by ILiveOnWacker »
Mine were shipped midweek so hopefully they are here soon. Can you post pics showing how to use the new buckle?
Will definitely reach out to Sofie about these.
It looks like the strap goes over the first two small holes from above, down through the 3rd, back up the 2nd and down through the 1st.
ILiveOnWacker
I’ll have to use my gps to get there!
I did it this way...skip over the top two holes, then down through the third, then up through the second and down through the one closest to the watch. On this watch I also tucked the end under the spring bar and ran it behind the watch.
sh333
Has thanked: 367 times
Been thanked: 298 times
Post by sh333 »
watchpalooza wrote: Sun Jun 23, 2019 2:30 am I did it this way...skip over the top two holes, then down through the third, then up through the second and down through the one closest to the watch. On this watch I also tucked the end under the spring bar and ran it behind the watch.
Doesn't that method of doing it make it way too bulky on the wrist?
EA-Sports
Has thanked: 22 times
Been thanked: 549 times
Post by EA-Sports »
I had the same issue when trying to tuck the end under the spring bar with the old hardware. I was hoping the new hardware would solve this problem and I wouldn’t need to tuck the end under the spring bar and I can trim the end so it’s not too long. We’ll find out in a few days when I receive the new hardware.
EA-Sports wrote: Sun Jun 23, 2019 4:12 pm
Definitely solved with the new buckle. It is not necessary to tuck under the spring bar...I just did it to get it out of the way until I am sure I want to keep it on this watch and commit to cutting off the extra length.
ILiveOnWacker
Thanks for the pics. When you cut it, do you need to burn the edges so they don’t fray? Or will that light the whole thing on fire!?
AndyS
Has thanked: 1320 times
Been thanked: 4400 times
Post by AndyS »
See my thread about the pajama strap style for another option in this stretch strap genre. Basically a single pass NATO out of the parachute strap material. Including holes and a traditional buckle.
Going to order another one or two tonight before the AliExpress sale ends.
