Jaxa Wrench?
Discussion area for watch books, tools and other related items.
Jaxa Wrench?
I tried a screwball, but the back of my DW-9600 hasn't budged. My next thought is to get a better tool for unscrewing the back of a watch, like a jaxa wrench. And I suppose I would also need a case holder.
I see the $180 Bergeon and the $85 LG and then cheap jaxa wrenches that go all the way to under $10.
What do y'all use?
Here is the patient:
Re: Jaxa Wrench?
I would probably rub some WD40 around the edge and try again with the screwball.
Find less chance of any inadvertent scratching.
OvrSteer
Re: Jaxa Wrench?
Post by OvrSteer »
I have the cheap version, and it can be hard to set the prongs exactly. There's a lot of potential for scratching the case if they're not right. If they *are* right, then it's super easy to screw the case back off and on.
I'm sure the name brand tools are better but $85 is just too much $$$ in my book.
Re: Jaxa Wrench?
I use one like this with a little bit of Scotch tape on the prongs. Haven't scratched a case back yet.
https://ebay.to/2DUNAEU
Re: Jaxa Wrench?
I have one of these 3 pronged wrenches and did scratch up one caseback. You have to be deliberate and take your time. If you are in a rush, just don’t do it.
I have seen some designs for 3D printed removal tools, but these are back specific. It is fine if you have a couple of watches or if you have somehow shandardized the casebacks in your collection (a bunch of Seikos). They would be plastic, so no chance of scratches.
[IMG]https://uploads.tapatalk-cdn.com/201902 ... fc1f0b.jpg[/IMG]
I also found a printable case for the Jaxa-style tool, which looks pretty awesome.
[IMG]https://uploads.tapatalk-cdn.com/201902 ... b9b1a8.jpg[/IMG]
Re: Jaxa Wrench?
I have been moving forward on this. I love the model-specific 3-D printed solution, but I am not patient enough :-)
I went in for one of the tools MoT suggested. I figured: yes, it is cheaply made, but among the cheap alternatives available to me its simplicity is an advantage. My judgment was rewarded when, after it arrived today, I realized it needed lock washers to keep the d***ned screw tops from coming loose. Home Depot had me covered for under $1:
UPDATE: Just a follow-up. While trying to open the watch, my tool, above, broke near the end (away from the handle) where the curve connects to the straight piece. In retrospect I wasn't smart about it: I had put one of the two pins at the very end. I should have guessed that it would be weak there. Anyhow, the G-Shock won round 1.
The seller was apologetic, offered to replace the tool, but agreed to refund my purchase. At the hardware store I picked up some adhesive and a couple tiny hose clamps. I just wanted the adhesive to hold the break together so it didn't move around. I put a hose clamp over each curved section to provide support. Here is the result:
I confess that I enjoy trying to do the most I can with the little I have. So, yes, I used a big pipe wrench as a makeshift bench vice. Over time I do look forward to owning more suitable tools. I wish I could say I didn't scratch the case back -- I should have used MoT's tape. :-) I was feeling impatient, which as noted above, is bad. I used the tape before and I think it made the pins less slippery as well as less scratchy. Onward and upward.
