Up for grabs is a beautifl Farer Lander. This one is in very good condition with only very minor wear, including very superficial scratches on the polished surfaces. Includes two genuine Farer leather straps which are worn but in very good condition. There is one very minor nick in the crystal right at 12:00 on the edge, which I tried my best to capture. It is not noticeable, to me at least, when worn. The crown is a bit stiff to turn, but Farer assures me that this is normal with the bronze crowns, and will loosen up with use, I just don't wear it very often.
Specifications:
39.5mm without crown
10mm depth
20mm lugs
10ATM water resistance
Domed sapphire crystal and exhibition caseback
ETA 2893-2 Top Grade movement
Asking $950 PayPalled and shipped to the US.
FS: Farer Lander GMT REDUCED!
Re: FS: Farer Lander GMT
Reduced to $925!
Re: FS: Farer Lander GMT REDUCED!
Sold elsewhere.
