Orient Ray Raven FAA02003B9
$130 shipped CONUS. PP FandF prefered
A little over a year old. I replaced the mineral crystal with a CrystalTimes CT020 domed sapphire with Blue AR. After replacing the crystal, I did not retest the water resistance.
The bracelet was sized the day I got it and worn once. Watch was worn on Nato straps since then and bracelet sat in the box.
Let me know if you have questions. Not sure why all the pictures uploaded sideways. If I have time maybe I'll redo them.
“Black stainless steel case with a black stainless steel bracelet. Uni-directional rotating (120 click) black stainless steel bezel. Black dial with black hands and dot hour markers. Minute markers around the outer rim. Dial Type: Analog. Luminescent hands and markers. Day of the week and date display at the 3 o'clock position. Orient calibre F6922 automatic movement with a 40-hour power reserve. Screw down crown. Solid case back. Round case shape. Case size: 41.5 mm. Case thickness: 13 mm. Band width: 22 mm. Fold over clasp. Water resistant at 200 meters / 660 feet. Functions: date, day, hour, minute, second. Dive watch style. Watch label: Japan Movt. Orient Ray Raven II Automatic Black Dial Mens Watch FAA02003B9.”
FS: Orient Ray Raven
Insta me: bbrou33
