Asking $325 Firm to lower 48 shipping. Listing here before putting on eBay. Near mint condition, only worn a few times with a Barton band. I never sized the bracelet. I have 100% rating on eBay and I’ve purchased and met Johnp moderator of the deal forum. Will ship usps priority. Comes with all original equipment and case.
Movement Japan made Miyota 9015 movement, 24 jewels, High beat 28800 bph, automatic winding, hacking
Power reserve 42 hours
Functions Hours, minutes, seconds and date
Water Resistance 300m screw down crown
Dial PVD coated Black, hour markers, pencil hands applied Super Luminova white color lume
Band 22mm PVD coated black, 316L Stainless steel PVD coated bracelet with 22mm at lugs tapering to 20mm at the fold over clasp with four micro adjustments.
Case 41.50mm wide, 48mm lug to lug length, 22mm lug, Brushed, PVD coated black
Case high 11.30mm thickness
Crystal Flat Anti-scratch sapphire double domed, anti-reflective coating inner
Lume Swiss made Superluminova White Lume by RC Tritec, white in daylight and darkness
Limited Edition Limited to unknown numbers and discontinued model
Bezel Bronze metal, 120 clicks unidirectional PVD coated bezel with Super Luminova White applied to markers
Crown Signed 'B' logo screw down crown
Case Back made of 316L Stainless Steel with engraved mermaid
FS: Borealis Portus Cale Bronze SOLD!!
Re: FS: Borealis Portus Cale Bronze
Had a smooth transition with [mention]Franko[/mention]
Buy with confidence
Buy with confidence
Sold outside MOT
