SUCCESSFUL : Brand Direct :Mileneal Prestige - 14 Aug 2019
Another Singapore based watch brand with 2 successful Kickstarter projects so far. Bad spelling aside, they're offering Miyota 9015 at USD 99 for the first 50 signups. It looks like a continuation/second run from the 2nd KS project linked below. Limited to 500 pcs. Delivery in December 2019. Comments seem generally favourable.
Link to Pre Order : https://mileneal.com/pages/prestige-automatic-pre-order
Specifications
CASE
316L Stainless Steel With Polished Bezel, Brushed Case & Case Back
Case diameter: 40 mm
Case diameter with crown: 43 mm
Case depth: 11.35 mm
Lug (band) width: 20 mm
Lug-to-lug: 47.5 mm
CRYSTAL
High Dome Hardened K1 With Anti-Reflective & Anti Scratch Treatment
DIAL
Fumé Dial With Sunburst Pattern
WATER RESISTANCE
5 ATM Water Resistant
MOVEMENT
Miyota 9015 Premium Automatic
24 Jewels
28,800 Vibration Frequency
42 Hour Power Reserve
STRAPS
Top Grain Leather With Croc-Embossed Pattern
Solid Stainless Steel Butterfly Clasp
Quick-release Pin
Specifications
CASE
Lug-to-lug: 47.5 mm
CRYSTAL
DIAL
WATER RESISTANCE
MOVEMENT
24 Jewels
STRAPS
Quick-release Pin
Re: PREORDER : Brand Direct Mileneal Prestige - 14 Aug 2019
Just to add a note: there's a possibility that the USD 99 offer maybe for Quartz like what was listed on the KS page and it could be mistakenly stated as Miyota 9015. However no mention of Quartz is listed on the new pre order page and if it's really the Miyota 9015, then it's really worth grabbing for movement alone. screen grab from a youtuber is posted below mentioning that it will be the Miyota 9015. Be aware this could be too good to be true too
Re: PREORDER : Brand Direct :Mileneal Prestige - 14 Aug 2019
Preorder to open on August 14th, 10:00AM GMT+8
I want a Vostok Classica in green, but appears to be well sold out. That green Mileneal might be a suitable replacement.
Preorder is live now.
and within 15mins, the USD 99 offer is over. now at USD 119 for another 50 pieces
Double post
Odd.
$120 just not as compelling.
Maybe but are there any other Miyota 9015 watches available for less than 120 USD?
Preorder at USD 139 now.
Less than 10 watches remain at USD 139.
Pricing has jumped to USD 159 and first 20 get a slim wallet for free.
Re: SUCCESSFUL : Brand Direct :Mileneal Prestige - 14 Aug 2019
To follow up, the Kickstarter campaign was
130 backers pledged Singapore $20,497 to help bring this project to life.
And link to the $159 brand direct is still live at - https://mileneal.com/pages/pre-order
