SOLD OUT : Worn & Wound - Laco Taupe Edition - Aachen & Augsburg
pgcity
Post by pgcity »
Preorder price is USD 460. The Aachen Taupe is limited to 300 pieces and the Augsburg Taupe is limited to 200 pieces. Expected delivery is in September.
Specs for both are as follows:
Laco Aachen and Ausburg 42
Case: Brushed Steel
Dial: LE Taupe Sunburst
Movement: Miyota 821A
Winding: Automatic
Lens: Sapphire
Strap: Brown Leather
Water Res.: 5 ATM
Diameter: 42mm
Length: 49.75mm
Thickness: 12mm
Lug Width: 20mm
Link to preorders are below:
Laco Aachen 42
https://windupwatchshop.com/collections ... 3444332610
Laco Ausburg 42
https://windupwatchshop.com/collections ... 3313752130
Re: PREORDER : Worn & Wound - Laco Taupe Edition - Aachen & Augsburg
Appears the Ausburg 42 is SOLD OUT. They have an "email me when available" button.
You can still purchase the Aachen 42 version for $460.
Re: SOLD OUT : Worn & Wound - Laco Taupe Edition - Aachen & Augsburg
The Aachen 42 now features an "email me when available" button.
Going to call it that these are SOLD OUT.
