SUCCESSFUL : Kickstarter: Von Doren Timepieces - URÆD automatic day/date watch
Von Doren Timepieces out of Norway, have launched their latest Kickstarter for the Swiss Made URÆD automatic day/date watch.
This is their third Kickstater following two successfully funded campaigns.
For the day wheel, you have the option of English or Norwegian weekdays.
Super Early Bird for English weekdays is about $779
Early Bird for English weekdays is about $834
Regular price will be about $1,529
Super Early Bird for Norwegian weekdays is about $779
Early Bird for Norwegian weekdays is about $833
Estimated delivery is May 2020
- Case size: 40mm. Thickness 13.4mm 46.2 mm lugs to lugs. Diver screwed in case-back with 6 notches.
- Movement: Automatic Swiss Made STP 4-13 self-winding movement. 26 Jewels, 28 800 vibrations 4Hz.
- Complications: Day, Date, Hacking Seconds, Hand Winding, Outer Day Wheel, Quick Date Correction, Quick Day Correction.
- Glass: Double domed bell-shape sapphire crystal with 5 AR coating inside. Flat sapphire crystal on case back.
- Watch case material: Brushed and polished stainless steel. Screwed in crown.
- Power reserve: 44 hours.
- Swiss Made: Assembled by hand.
- Option: Of English or Norwegian days in day window.
- Bezel: 120 clicks bi-directional bezel. Sapphire crystal.
- Bracelet & strap: Delivered with both Silicone rubber strap and high quality 3 solid link bracelet with deployant buckle. Double lug holes. The bracelet is delivered with fitted end-links (not shown on photos of prototype bracelet).
- Lug width: 20mm.
- Water resistance: 100m = 300ft
Ole Brude designed a revolutionary lifeboat way ahead of his time; A closed lifeboat made of steel, shaped like an egg. To prove that closed lifeboats was the future Brude decided to sail from Ålesund, straight across the Atlantic Ocean, and end the journey in Boston.
The voyage became a huge success despite severe storms and hurricanes, and the crew was celebrated as heroes. Ole Brude even received an audience with President Roosevelt.
qrocks
Re: PREORDER: Kickstarter: Von Doren Timepieces - URÆD automatic day/date watch
Post by qrocks »
I expect the folks buying these will be very happy with their purchases.
Make time to take time.
Re: SUCCESSFUL : Kickstarter: Von Doren Timepieces - URÆD automatic day/date watch
753 backers pledged NOK 6,114,823 to help bring this project to life.
You can preorder directly from Von Doren for €1,379 (about $1,560)
https://www.vondoren.com/uraed
