SUCCESSFUL : Kickstarter: Reverie Watches - The Diver
Reverie Watches out of Singapore have just launched their latest Kickstarter for their latest collection, The Diver automatic.
Even though this is their fourth model, this is only their second Kickstarter campaign to date.
Super Early Bird pricing is around $327 SOLD OUT
Early Bird pricing is around $338
Regular pricing will be $500
Estimated delivery is December 2020
The Diver will be available in three colorways - navy, olive green, or warm grey.
- 316L Stainless Steel Case. Brushed and high-polished surfaces for contrast. 120-click unidirectional rotating bezel also provided.
- Dimensions: 40mm diameter, 43mm lug-to-lug, 11mm thickness and 20mm lug-width.
- Miyota 9039 Movement. Premium Japanese automatic movement with a 42 hours power reserve, hacking seconds function and high frequency of 28,800 per hour.
- Movement Engraving. The Japanese ‘Seigaiha’ pattern (i.e. “blue sea and waves”) is engraved on the rotor as a tribute to the movement’s Japanese roots and the watch’s aquatic theme.
- Guilloché Dial with 3 Color Choices. Double-layer dial with our signature guilloché effect displays different color tones depending on lighting conditions. Choose from: (1) navy; (2) olive green; and (3) warm grey.
- Super-LumiNova. 2 types of Super-LumiNova luminous material aid reading the time in the dark: BGW9 (blue) on the hands and C3 (green) on the hour markers and bezel marker.
- Sapphire Crystal. Sapphire crystal with AR-coating minimizes glare when telling the time.
- Screw-Down Crown & 20ATM Water Resistance. Water resistance up to a depth of 200m.
- Adjustable Tapered Bracelet. The brushed stainless steel bracelet includes: (1) a 6mm taper for comfort; (2) on-the-go adjustability allowing you to adjust the bracelet by up to 11mm quickly; and (3) easy removal design allowing you to swap out the bracelet for another strap without a tool.
- Additional Rubber Strap. 20mm wide strap which tapers down to 18mm at the buckle. The strap will also have an easy removal design allowing you to change straps without a tool.
- Limited Quantities. Limited edition with each watch’s number engraved on the case-back.
- Watch Roll. Each watch comes with a leather travel roll which fits up to 4 watches.
- Free Worldwide Shipping. Complimentary tracked shipping via DHL Express.
- Warranty. 2 year international repair warranty provided.
Re: SUCCESSFUL : Kickstarter: Reverie Watches - The Diver
81 backers pledged S$ 39,254 to help bring this project to life.
You can still preorder the Diver direct from Reverie.
https://www.reveriewatches.com/store/p24/Diver.html
The current preorder price is $360
*NOTE* - Prices increase by $15 each month until December.
Save 27% off $500 RRP by ordering this month.
Because they appeared to hit some stretch goals, they are now offering another colorway, Burgundy, and an option for a 12 hour bezel.
