King Watch Company outside of Phoenix, AZ have launched their first Kickstarter for their updated Legacy Diver. Though this is their first campaign, they have released five collections through their own website.
Super Early Bird pricing is $199
Early Bird pricing is $269
No word on regular pricing.
Estimated delivery is March 2021
The Legacy Diver 200 is the 2nd part of a 4-part Legacy Series. Below are the Legacy Series Lineup:
- Legacy Class One 2019 - Dress Watches Sold out Immediately.
- Legacy Diver 2020 - Diver Watches
- Legacy Pilot - Early 2021 Release on Kickstarter
- Legacy Chronograph - Late 2021 Release on Kickstarter
All Legacy timepieces will be limited to 1000 pieces per color-way. All timepieces will be individually numbered. You cannot chose the numbers that will be sent to you.
UPDATES TO THE NEW KING LEGACY DIVER 200 (actual photos are of the previous 42mm version):
- Now using the Seiko NH35 Movement instead of the Miyota 8215.
- A 40mm 316L Stainless Steel Case. Brushed and Polished.
- 13mm Case Thickness.
- Fully Lumed Ceramic Bezel with Super LumiNova BGW9.
- Solid, screw down H-Links polished and brushed throughout.
- Date Window will be at 6 o'clock position.
The Legacy Diver 200 will come in two colorways, blue dial with blue bezel or black dial with black bezel.
- 200 Meter Water Resistance
- Fully Hardened Stainless Steel Case at 40mm and 13mm thick.
- Forged stainless steel bracelet sized at 20mm that tappers down to 18mm.
- Solid end links and solid center links, brushed and polished.
- Drilled Lugs and Screw in H-Links
- 120 Click Uni-directional Ceramic Lumed Bezel
- Flat Sapphire Crystal with double AR coating.
- Swiss SuperLuminova BGW9 Lume - 8 Layers
- Hand Applied Stainless Steel Indices
- Seiko NH35 Movement
- Engraved Screw Down Crown
- Sealed and engraved case-back with logo, serial numbers and model numbers.
- All out timepieces come with our standard 24 month warranty.
CANCELED : Kickstarter: King Watch Co - Legacy Diver 200
Re: PREORDER: Kickstarter: King Watch Co - Legacy Diver 200
Those look pretty good, and $199 is hard to beat.
But the alignment in the renders.
Perfectly fine date at 6 in the renders. Then 3:19 in the production model?!?
EDIT: Saw the note about the photos being the old model. Good! That is nuts.
Anytime you see miss alignment, close one eye and check again. They seem pretty good to me. [emoji106]ManOnTime wrote:Those look pretty good, and $199 is hard to beat.
Nikon Z6
Tudor Black Bay Steel
Longines Hydroconquest GMT
Breitling Chronomat
Alpina Alpiner Extreme
Bulova x Complecto Jet Star
Brew Retromatic Copper
Fossil Mickey Mouse
Ernest Borel Athletic
Casio GWB5600AR-1
G-Shock DW5040PG
Breitling Chronomat
Fossil Mickey Mouse
Casio GWB5600AR-1
G-Shock DW5040PG
As long as they don't order their other catalog parts from Seiko, they should be fine for production!
agreed on previous comments, nice deal for $199. If the bracelets are straight forward decent quality, this deal seems like a winner for a lot of folks.
Oh, I do miss the days when I had room in my watch cases for $199 watches. I do love to shop still though!!!
Make time to take time.
Re: CANCELED : Kickstarter: King Watch Co - Legacy Diver 200
CANCELED
Funding for this project was canceled by the project creator on Nov 1 2020
CANCELED
Message from creator:
We will be back
Cancelled our project due to design changes. We needed to create a different version of this a project. We will update you all soon.
We will be back
