PREORDER: Brand Direct: Ball Watch - Engineer Master II Waco Glider
The latest preorder from Ball is for the 46mm mechanical Engineer Master II Waco Glider.
Did I mention it was 46mm?
Limited to 1,943 pieces each to commemorate the year that the Waco CG-4A gliders went into active duty, the Engineer Master II Waco Glider is available to preorder from Ball for an exclusive price until January 13, 2021.
https://shop.ballwatch.ch/en/waco
Ball Engineer Master II Waco Glider
Preorder price is $2,099
Regular price is $2,249
Ball is offering free engraving on the caseback and a complimentary green NATO strap for a change of look.
LIMITED EDITION
- 1,943 pieces each
WEIGHT
- Approx. 120g
MOVEMENT
- Manual caliber BALL RR2102
SIZE (CASE)
- 46mm
HEIGHT
- 12.7mm
WATER RESISTANCE
- 50m/165ft
ANTI-MAGNETISM
- 1,000 Gauss (80,000 A/m)
MICRO GAS TUBES
- 26 micro gas tubes on hour and minute and dial for night reading capability
FUNCTIONS
- Hours, minutes and subsidiary seconds
CASE MATERIAL
- Stainless steel
- Sapphire crystal transparent window
- Hinged case back
CROWN
- Push-in crown
CRYSTAL
- Anti-reflective sapphire crystal
DIAL COLOR
- Black, Blue, or Green
BRACELET
- Calf leather strap with pin buckle
LUG WIDTH
- 22mm
LUG TO LUG
- Approx. 53.5mm
