UNSUCCESSFUL: Kickstarter: Southern Cross Watch Company - Southern Hemisphere Moonphase
This is one is strictly for the members in the southern hemisphere, an accurate moonphase watch as you see it!
[img][/img]
[img][/img]
Super early bird pricing is about $180
Early bird pricing is about $190
Regular Kickstarter backing is $200
Retail will be $267ish
[img][/img]
Southern Cross Watch Co has come up with an adaptation of the Miyota 6P24 movement to show the phases of the moon as seen in the southern hemisphere.
[img][/img]
- 40mm case diameter
- 10mm thickness
- 47mm lug to lug
- 20mm lug width
- Screw-on case back
- 316L stainless steel
- Miyota Calibre 6P24 movement
- Stainless Steel Milanese mesh strap
- Nylon Nato strap with stainless steel fittings
- Strap Changing Tool
- 3yr Battery life
- Hardened Mineral Glass Crystal
- Water resistant to 3ATM
- 3yr Warranty
Re: Preorder: Kickstarter: Southern Cross Watch Company - Southern Hemisphere Moonphase
Mineral Glass on a kickstarter is a disappointment. Other than accurate graphics for the southern hemisphere, not sure this stands out much from many similar sub-$100 watches from established brands. Warranty is only good if the company lasts 3 years...
Totally agree.
But that unique complication was enough for me to want to shine a light on it.
Because that could be enough for someone to pull the trigger.
Thrax
Post by Thrax »
This looks so unbelievably cheap. Like they bought a $20 watch from AliX and home-printed a dial with a generic "handwriting" font that comes with Windows.
Re: UNSUCCESSFUL: Kickstarter: Southern Cross Watch Company - Southern Hemisphere Moonphase
To follow up, this Kickstarter campaign was...
UNSUCCESSFUL
The project's funding goal was not reached on Sun, April 7 2019 3:00 AM EDT
