As I try to focus on Kickstarters that have something different, unique, or compelling, this one definitely checked some boxes.
The Horizon Timepiece Stealth Automatic
Unfortunately, the Super Early Bird pricing slots of $199 are gone.
But plenty of Early Bird available for $221
Regular price will be around $417
What's different about this one is the dial has a 12 hour ring that you can tell the time from a window between the case.
From their description:
"Designed for discreet and quick viewing of the time from the side; we have custom made the case, glass and hands. The uniquely designed watch glass allows time to to be readable from the side of the watch. The watch case is designed in two parts to securely hold the glass in between, and giving it the unique aesthetic with the laser cut roman number on top of the glass. The time can be read from the face and side of the watch. The numbers and markings on the side move in a 12-hour rotation."
Although I'll admit that in the pics below, the index track on the side of the watch looks slightly wonky. Hopefully that's just a prototype issue that would be resolved with the final product.
There are three colorways and here are the specs (it's a big one):
- Case: 316L stainless steel
- Movement: Miyota 8215 automatic movement
- Glass: Sapphire crystal
- Strap: Cowhide Leather
- Case size: 45mm
- Case Thickness: 15mm
- 3ATM water resistant
SUCCESSFUL: Kickstarter: Horizon Timepiece - Stealth auto
- Has thanked: 46882 times
- Been thanked: 35280 times
Re: SUCCESSFUL: Kickstarter: Horizon Timepiece - Stealth auto
82 backers pledged $40,318 (Singapore dollars) to help bring this project to life.
