SUCCESSFUL: Kickstarter: Ganymede Watches - Series 01
Ganymede watches is launching their first Kickstarter for a vintage/steampunk-esque model, the Series 01
I do like gimmicky watches, but the four hand dial system seems a little overly complicated. But sure it's something one gets used to.
But the difficulty in reading time and only colorways are bronze PVD or rose gold PVD, not one for me.
Kickstarter pricing for either colorway is $350
Regular pricing will be $425
Estimated delivery is November 2019
From their description:
"For the Series 01, the specific inspiration for the case and window comes from vintage diving helmets also known as copper hats and the pod shaped style of old submarines."
To read the time, the special four pointed colored hand corresponds to the color of the text on the dial. The following illustrations and video show how to read the time:
Video link for how to read the time:
https://ksr-video.imgix.net/assets/024/ ... 4_high.mp4
Specifications:
- Case diameter: 34x49.5 mm
- Case thickness: 13.5 mm
- Dial: Brushed black dial
- Hand: Custom four pointed hand with luminous points
- Strap width: 18 mm
- Crystal: Domed sapphire glass on front, flat sapphire glass on case back
- Case material: 316L Stainless Steel, with options for Bronze PVD, Rose Gold PVD
- Case back: 316L Stainless Steel
- Strap: Brown distressed premium leather with cream cross stitching, white distressed premium leather with white cross stitching
- Water Resistance: 100m with screw down crown
- Movement: Seiko NH35A automatic movement
Re: Preorder: Kickstarter: Ganymede Watches - Series 01
This is a Rube Goldberg machine. Ridiculously overcomplicated system for indicating time.
baldrick
Post by baldrick »
Bonkers. I love it for its creativity, but would never wear it.....
baldrick wrote: Fri May 17, 2019 1:33 pm Bonkers. I love it for its creativity, but would never wear it.....
Agreed. And it would be cool if you could actually read it fairly easy but they chose not to make the display very large or legible.
I don't understand why at some times (4, 8, 11) there are two hands pointing at the same number, but other times there are only 1?
Boourns wrote: Fri May 17, 2019 1:55 pm I don't understand why at some times (4, 8, 11) there are two hands pointing at the same number, but other times there are only 1?
Because it is a poor design. I am all for innovation and creativity, but this one should never make it to production,
FTE wrote: Fri May 17, 2019 1:59 pm
If Xeric can figure it out, can't be that hard.
FTE wrote: Fri May 17, 2019 11:07 am This is a Rube Goldberg machine. Ridiculously overcomplicated system for indicating time.
Absolutely.
And I love it.
With 8 days to go, this campaign is 76% funded.
It'll be a close call if this one is successful or not.
Re: SUCCESSFUL: Kickstarter: Ganymede Watches - Series 01
72 backers pledged $24,606 to help bring this project to life.
If you are still interested in preordering, you can do so directly from Ganymede at https://ganymede-watches.com/shop
