I picked up a Timex T3B791 perpetual calendar and could not find much by way of instructions online for how to set the month, day and date. The instruction manual from Timex suggests to send the watch into a Timex service center for battery changes and calibration using the recessed pushers...that simply won‘t fly.
After some experimentation, here is what I found...hopefully this can help others:
1) Pull the crown out to the middle position
2) Open the case back and use a toothpick to push the reset button just below the battery. The fourth center hand will move to a number from 1 to 4, indicating the number of years from leap year.
3) Push the top pusher from 1 to 4 times to set the number of years from leap year
4) Push bottom pusher once, then use top pusher to set month.
5) Push bottom pusher once, then use top pusher to set date.
6) Push bottom pusher once, then use top pusher to set day of the week.
7) Push in crown and screw down
8) Replace case back
Edit: added step 3 for leap year setting (thank you, [mention]yinzburgher[/mention]).
How to set a Timex Perpetual Calendar
- Has thanked: 21586 times
- Been thanked: 12443 times
- Wolfsatz
- Has thanked: 272 times
- Been thanked: 2485 times
Re: How to set a Timex Perpetual Calendar
Great Pick up. My only Perpetual Timex is the Yacht Racer.. still ticking fine after 3+ years. But this info should be handy! Thanks!watchpalooza wrote: ↑Sat Dec 07, 2019 4:12 am I picked up a Timex T3B791 perpetual calendar and could not find much by way of instructions online for how to set the month, day and date. The instruction manual from Timex suggests to send the watch into a Timex service center for battery changes and calibration using the recessed pushers...that simply won‘t fly.
3) Push bottom pusher once, then use top pusher to set month.
4) Push bottom pusher once, then use top pusher to set date.
5) Push bottom pusher once, then use top pusher to set day of the week.
6) Push in crown and screw down
7) Replace case back
... What time is it?
- Has thanked: 21228 times
- Been thanked: 23299 times
Hopefully the year was set correctly too and it's up to the task.
Actually I hadn’t thought about this. Checked this morning and sure enough the watch was showing March 2. Is there a way to calibrate the year on these to align with the leap year cyccle, or is it an every 4 year reset? Would seem that a “perpetual” calendar would allow for alignment this way, but I find nothing online (since Timex recommends setting only by a qualified service center). I do find a second button inside labeled “360”...but no idea what this one does. Anyone know? I am the type of person who will be bothered by this slight imprecision, even though it will only manifest every 4 years.yinzburgher wrote: ↑Sat Feb 29, 2020 11:01 am Hopefully the year was set correctly too and it's up to the task.
Here is the watch after correction if the date:
Bummer. I found a video below that explains how to know what year (in relationship to the leap year) the watch is set to. I believe this should be the same movement. I originally found it the video HERE after hitting the HOW IT WORKS button. What the video does not explain unfortunately is how to change it once you know how it is set. Also, this year being leap year, would you want the pointer set to the 1 or the 4? I'm guessing the 4 by the way it is worded but I'm not certain.
I think the video below may explain how to set it. Although it helps if you can read Turkish and tolerate terrible music. It is for models T2N502-T2N503-T2N504-T2N505-T2N506-T2N507-T2N567-T2N568-T2N571 but once again I think it may be the same movement. I think you'll figure it out. You're good at this stuff.
Thank you...that did the trick, and I have updated the instructions above accordingly.yinzburgher wrote: ↑Sat Feb 29, 2020 11:01 am Hopefully the year was set correctly too and it's up to the task.
