Minor usability suggestion
Having an issue with the site, or with posting? Create a thread and someone will help as soon as possible.
cel4145
Post by cel4145 »
If you happen upon an easy way to do this (might require theme editing, so might not be easy), I recommend moving the report, quote, and like menu to the bottom of the display:
That's because one always uses those things *after* reading a post, and so it is handier to have it at the bottom than to have to scroll back up the top of the post. I am actually surprised that phpBB would put them at the top as the default given that obvious usability reason.
Re: Minor usability suggestion
cel4145 wrote: Fri Dec 21, 2018 1:03 pm If you happen upon an easy way to do this (might require theme editing, so might not be easy), I recommend moving the report, quote, and like menu to the bottom of the display:
Good idea.
I'm not sure how easy/difficult it would be, but I will look in to it.
