SUCCESSFUL: Kickstarter: Monsieur Watches - Ranomo chronograph (mechanical or quartz)
Monsieur Watches out of Singapore have launched their second Kickstarter for the Ranomo chronograph, available either as a mechanical or quartz.
FYI, their first Kickstarter was successfully funded.
Super Early Bird pricing for the ST1901 mechanical is $368
Regular price will be $468
Super Early Bird pricing for the Miyota 0S21 quartz is $199
Regular price will be $299
Estimated delivery is December 2019
In addition to choice of movement, the colorway options are panda or reverse panda.
Mechanical versions:
Quartz versions:
- Case Diameter: 38 mm Case
- Thickness: 10 mm
- Band Material: Genuine Italian Leather Band
- Band Width: 20 mm
- Total Weight: 40 g (Miyota 0S21)/ 46.5 g (Seagull ST1901)
- Case Material: 316L
- Back Plate: Engraved Steel (quartz) / Sapphire Crystal Exhibition Back (mechanical)
- Buckle: Standard Brushed Buckle
- Buckle Material: Stainless Steel
- Dial Window Material: K1 Domed Sapphire Coated
- Display: Chronograph
- Movement: Japanese Miyota 0S21/ Seagull ST1901 Hand-Wound
- Date Function: Yes (quartz only)
- Seconds Function: Yes
- Water Resistant: 5 ATM / 50 Meters
Re: PREORDER:Kickstarter: Monsieur Watches - Ranomo chronograph (mechanical or quartz)
It's an SSB003, which is not a bad thing.
Re: SUCCESSFUL: Kickstarter: Monsieur Watches - Ranomo chronograph (mechanical or quartz)
48 backers pledged S$ 27,410 to help bring this project to life.
