PREORDER : Brand Direct: RJM Bluebird by REC Watches
pgcity
Post by pgcity »
Link to pre-order is here https://www.recwatches.com/products/rjm-BLUEBIRD
Only 334 pieces to be made at USD 1295 per watch.
TECHNICAL SPECS
DIMENSIONS
Diameter 41mm
(40mm without crown protector)
Height 10.9mm
Opening diameter 33mm
Weight 78g
FEATURES
3 Hands w. lume/ Date
Blue Sunburst dial w. luminous
Stainless steel case
Stainless steel bezel
2 years full warranty
3 ATM, 30 meters
MOVEMENT
Reference Miyota cal. 9015 movement with rotor decoration
Type Mechanical, self-winding
Frequency 28,800 VPH (4.0 hz)
Power reserve 42 hours
Jewels 24
MATERIALS
Case 316L Stainless steel
Top glass Sapphire Crystal with 3 layers of anti-reflective coating
Caseback glass Mineral Crystal
DIAL
The handcrafted and untreated aluminum dial is cut directly from the wings of the PT879 MK IX Spitfire aircraft. Every dial features the original marks and dents of its Spitfire aircraft donor. This also means that every dial is visibly unique.
STRAP
Strap Width 20 mm
qrocks
Re: PREORDER : Brand Direct: RJM Bluebird by REC Watches
Post by qrocks »
very interesting. thanks for posting.
Make time to take time.
Still hate the extended date window, but at least they found a way to incorporate it into the design.
At $1300, we are clearly still paying for WWII.
REC is offering a free extra strap for the first 100 to preorder the Bluebird.
