SOLD OUT : Brand Direct: Maison Celadon - Premier and Premier Helvetia
From Maison Celadon:
To commemorate our seventh anniversary this year, we'll be launching the Premier with the special Seventh Anniversary Edition limited to 100 pieces. This launch is combined with our 100X Campaign, where we will donate 100% of all net proceeds from the sale of all 100 Premier Seventh Anniversary Edition watches to our adopted dog shelter Gentle Paws (https://www.facebook.com/GentlePaws/), which will be enough to fund them fully for a year. After seven years of fighting the good fight, we have not forgotten our mission to create Watches of Excellence, and to be a Force for Good. The Premier Seventh Anniversary Edition is our tribute to the silent indomitable heroes who care for these dear abandoned and homeless dogs in spite of the daily hardship and heartache they endure.
The Celadon Premier, an excellent and elegant Chinese luxury watch robust and versatile enough for everyday wear. The Premier carries on the two most distinctive guilloche dials of the Imperial - the Red Plum Blossom and Blanc de Chine ****, now with an added centre seconds hand (blued on the ****). It is equipped with the reliable Celadon-Grade B15 automatic movement, the same movement used in the Yue Fei, made for us by Beijing Watch Factory to our higher standards and put through three additional layers of quality control.
The pre-order price of the Premier is 711 Singapore dollars (approx $518 USD)
Blanc de Chine **** - https://celadonhh.com/collections/premi ... -****-1
Red Plum Blossom - https://celadonhh.com/collections/premi ... mier-red-1
Technical Specifications of the Premier:
General -
- available with Plum Blossom guilloche in Imperial Red, or **** guilloche in Blanc de Chine
- 2 year global warranty
Movement -
- Celadon-Grade B15 (made to a higher standard and put through three additional layers of quality control)
- automatic movement
- 21,600 vph
- approx 42 hour power reserve
Dial and Hands -
- oil-pressed guilloche dial
- double-faceted hour and minute dauphine hands
- tri-faceted hour markers
- centre seconds hand (blued steel on the ****)
Case -
- 316L stainless steel
- robust and contemporary case
- hand-brushed finishing
- hand-polished scoops at lug sides
- screwed down caseback
- 100m water resistant
- 39mm case diameter
- 9mm thin
- 20mm strap width at lugs
- front double-domed sapphire crystal with anti-reflective coating
- "**** encircling the peonies" engraved artwork on caseback, designed by Celadon Founder Benjamin Chee HH
Strap -
- signed tang buckle
- navy or grey calf leather strap with signed imperial red lining
- a wide range of ready-made and bespoke straps available as options
_____________________________________________________________________________________________________________
Similar, but widely different is the Premier Helvetia
The Premier Helvetia is a special version of the Premier equipped with the Soprod M100 Swiss automatic movement, in its highest R4 grade which is regulated to within 4 seconds per day, giving it an astonishing accuracy of 99.99%. The standard Soprod M100 is already equivalent in finishing to the ETA2892 Top grade, while being of a superior design, and the R4 variant we use is even better of course.
The Premier Helvetia Seventh Anniversary Edition is limited to only 50 pieces.
The pre-order price is 648 Singapore dollars (about $1192 USD), with a 50% deposit of 824 Singapore dollars (approx $596 USD) due on order, and the remainder just before delivery in Dec/Jan.
Blanc de Chine **** - https://celadonhh.com/collections/premi ... ia-****
Red Plum Blossom- https://celadonhh.com/collections/premi ... lvetia-red\
71769339_2317832018530741_5552106598656114688_n_495e2da7-7237-451e-a9c4-1bff8334353a_1080x.jpg
71769339_2317832018530741_5552106598656114688_n_495e2da7-7237-451e-a9c4-1bff8334353a_1080x.jpg (41.63 KiB) Viewed 2689 times
Technical Specifications of the Premier Helvetia:
General -
Movement -
- Soprod M100 R4 Grade (regulated to within 4 secs/day, a 99.99% rate of accuracy)
- Swiss automatic movement
- 28,800 vph
Dial and Hands -
Case -
- 9mm thin
Strap -
qrocks
Re: PREORDER: Brand Direct: Maison Celadon - Premier and Premier Helvetia
Post by qrocks »
Fine cause. I hope they do well with the campaign!
Make time to take time.
