2020 New and Upcoming Releases!
Locked
Re: 2020 New and Upcoming Releases!
Boourns wrote: Thu Feb 13, 2020 8:25 am18.5mm :shock:
That's even a bit much for me!
pdsf
Post by pdsf »
Boourns wrote: Thu Feb 13, 2020 8:52 am
pdsf wrote: Thu Feb 13, 2020 8:33 am @Boourns's signature :lol: :lol:
At first I was joking, but then I saw those Bell & Ross releases were 41mm so I just did it.
oh I think it's great! I hope you keep it. I really do always feel that way. :)
pdsf
Post by pdsf »
ManOnTime wrote: Thu Feb 13, 2020 9:09 am
That says a lot. :lol:
You may have seen elsewhere on this forum that Invicta (yep!) has released a homage to the original 1953 Rolex Submariner. You won't find any articles or reviews of this watch from the main watch publications but I think it's worth posting here for a few reasons. This is an opportunity to pick up a watch that is known to be a popular modding platform and DOES NOT have Invicta engraved on the side of the case unlike many other 40mm automatic Pro Divers. I also think that many will find this to be a very good looking watch without any modifications at all. And I think it's possible that we could see more non-engraved 40mm NH35 divers from Invicta following this release. Also, the price is right. Check out the ShopHQ link for a video that shows the watch in greater detail.
LINK TO THE INVICTA PRO DIVER 31290
THE 31290 PRO DIVER ON SHOPHQ
Details and Specifications
Brand and Model: Invicta 1953 Pro Diver 31290
Case Material: Stainless Steel
Case Diameter: 40mm
Lug width: 20mm
Thickness: 14mm
Bezel: Unidirectional rotating
Crown Type: Screw Down
Crystal Type: Flat mineral glass
Case Back: Screw down exhibition
Movement: Seiko/TMI NH35A automatic
Water Resistance: 200m/20 ATM
Bracelet: Brushed stainless Steel
Length: 210mm
The original 1953 Rolex Submariner
Based on customer feedback, Oris has launched a 41.5mm Aquis as an in-between size to join the 39.5 and 43.5 sizes. So far I only see one model on the Oris site although it is available on both bracelet and rubber strap. The IG posts below show 41.5mm models but I'm sure if it is the same model on the Oris site. The dials appear black to me.
LINK TO THE 41.5mm ORIS AQuIS DATE
INFO ON MASTER HOROLOGER
Brand and Model: Oris Aquis Date
Reference: 01 733 7766 4135-07 8 22 05PEB on bracelet
Reference: 01 733 7766 4135-07 4 22 64FC on rubber strap
Case material: Stainless steel
Case diameter: 41.5mm
Lug width: 22mm
Thickness: 12.7mm
Bezel: Unidirectional rotating w/ ceramic insert
Crystal: Sapphire double-domed w/ anti-reflective coating inside
Caseback: Stainless steel screw-down w/ see-through mineral glass
Water resistance: 300m w/ screw-down crown
Dial: Blue w/ Superluminova BG W9
Movement: Oris 733 automatic, base Sellita SW 200-1
Availability: February 2020
Price: CHF 2,000 (metal bracelet) or CHF 1,800 (rubber strap)
Sternglas has introduced their first Swiss made automatic, the Kanton.
https://www.sternglas.com/products/kanton
Pricing is $879 or €799 depending on currency.
From their email announcement:
- The new Kanton is once again the product of feedback from and close collaboration with the Sternglas community - and this is the result.
- The Swiss STP 1-11 caliber movement with a maximum power reserve of 44 hours makes the Kanton the most high-quality tiempiece by Sternglas.
- The ornate movement of the watch, complete with its deep-etched rotor and blued screws, can be observed as it turns through the sapphire crystal base.
- The Kanton is available with a new quick-change leather strap in brown and black. The special feature is the decorative stitching.
- The 39mm polished, stainless steel exterior sits comfortably on the wrist and under the sleeve at the height of 10mm.
- The luminous hands by Luminova and illuminated spots make it easy to tell the time, even at night.
yinzburgher wrote: Fri Feb 14, 2020 10:31 am Based on customer feedback, Oris has launched a 41.5mm Aquis as an in-between size to join the 39.5 and 43.5 sizes. So far I only see one model on the Oris site although it is available on both bracelet and rubber strap. The IG posts below show 41.5mm models but I'm sure if it is the same model on the Oris site. The dials appear black to me.
Lug width: 22mm
Thickness: 12.7mm
If I was at Oris, I would just make the one model in this size in a popular colorway to test the waters to see if this size actually sells or not.
Seems exhausting to have three sizes of the same watch, so many SKUs to keep track of.
TheJohnP wrote: Fri Feb 14, 2020 10:44 am Sternglas has introduced their first Swiss made automatic, the Kanton.
This looks great. Here's a movement shot since they talked it up:
And, hey, I'll take 39mm :lol:
TheJohnP wrote: Fri Feb 14, 2020 10:51 am If I was at Oris, I would just make the one model in this size in a popular colorway to test the waters to see if this size actually sells or not.
I was surprised Chris Ward did this, too, with the new 3d gen trident. It comes in 38, 40, and 42. I suppose as long as the movement fits in the 38mm it's not that much harder to do?
yinzburgher wrote: Tue Jan 21, 2020 2:19 am Sorry for the poor quality images......best I can find at the moment but I'll try to remember to update at some later point. You might remember these October releases from Seiko HERE. Well meow Seiko is releasing similarly styled 3-hand Presage models with either white/silver, black or green dials.
References: White SARX069; Green SARX071; Black SARX073
Case material: Stainless Steel
Crystal: Sapphire Glass with anti-reflective coating
Movement: Caliber 6R35 automatic
Power reserve: approx. 70 hours
Accuracy: + 25 sec to – 15 sec / day
Case size: 48.3 mm x 41.3 mm x 11.3
Luminous paint (Hands and indices)
Rotating bezel
Screw back case back
Limited edition: 1964 pieces each
Release date: End of February
Price: ¥91,300 JPY or approximately $830 USD
These Seiko Presage models that pay tribute to the Crown Chronograph are now up on Seiko's website. LINK HERE. From left to right the alternative reference numbers are SPB129J1, SPB127J1, and SPB131J1.
And as you can see from the leaked catalog page below, there will be a blue limited edition version as well, the SARX081. Also of note is a coral blue Prospex Sumo SBDC113 which should have a 6R35 and sapphire.
yinzburgher wrote: Thu May 16, 2019 10:32 am Timex has once again gone back through its archives and now brings us the Q Diver Reissue. The company started making quartz watches in 1972. But it wasn't until 1979, with the release of the Q diver, that they made the switch from mechanical watchmaking to fully embracing quartz technology.
TIMEX Q DIVER REISSUE PRESS RELEASE
LINK TO THE Q DIVER ON THE TIMEX WEBSITE
BUY IT HERE FOR $179
"First released in 1979, our original diver-inspired Q Timex gave a new generation a modern Timex® watch with quartz technology. A true reissue, we recreated every detail—including the true-to-the-era woven stainless-steel bracelet, functional battery hatch, rotating top ring, luminescent paint and ticking inside is a modern quartz movement."
Reference: TW2T80700ZV
Band Color: Stainless Steel
Buckle/Clasp: Clasp (Self-Adjust)
Case Color: Stainless Steel
Case Finish: Brushed/Polished
Case Shape: Round
Case Size: Full Size
Crystal/Lens: Acrylic
Dial Color: Blue
Dial Markings: Markers (Full)
Water Resistance: 50 meters
Top Ring Color: Blue
Top Ring Material: Stainless Steel
Band Material: Stainless Steel
Case Height: 11.5 mm
Strap and Lug Width: 18 mm
Case Width: 38 mm
Movement: Seiko quartz caliber PC33
Attachment Hardware Color: Stainless Steel
Diver Inspired
Domed Acrylic Crystal
Rotating Top Ring
Luminant Hands
Caseback ‘True to the Past’ with Battery Hatch
ESQUIRE MAGAZINE ARTICLE
PROFESSIONAL WATCHES ARTICLE
HODINKEE ARTICLE
There will be more Timex Q Reissue colorways coming this spring, including a white dial with pepsi bezel, blue with orange, and black with green. Sign up HERE to be notified when they are available.
Sigh, Timex and their liberties with history. They were making "fully quartz" watches at least 3 years prior to 1979, LCD ones, even.
FilthyWatchTan
Post by FilthyWatchTan »
ManOnTime wrote:Sigh, Timex and their liberties with history. They were making "fully quartz" watches at least 3 years prior to 1979, LCD ones, even.
I think they meant fully switched over to quartz
FilthyWatchTan wrote: Sat Feb 15, 2020 12:45 am
But that would be incorrect as well. Timex produced in-house mechanical movements and watches until 1996.
Mido has put out an interesting and unique new colorway of the Commander. A lugless monocoque case and Milanese mesh with a black PVD finish and a gradated blue dial.
MIDO COMMANDER BLUE SHADE
MIDO PRESS RELEASE
MIDO ON INSTAGRAM
WRITE-UP ON WATCH I LOVE
Brand and model: Mido Commander Shade Blue
Reference: M8429.3.25.11
Case Material: Stainless steel with black PVD coating
Diameter: 37.00 mm
Between lugs: 20.00 mm
Water-resistance: 5 bar (50 m / 165 ft)
Crystal: Acrylic glass
Case height: 10.45 mm
Movement type: Automatic
Elaboré-grade Automatic Mido Caliber 80 (base ETA C07.621)
Dial colour: Blue
Hour Markers: Applied indexes
Bracelet: Milanese mesh in stainless steel with black PVD coating
Available now
Price: $810 USD
Locked
