Show Off Your New Strap/Bracelet
recapt
Re: Show Off Your New Strap/Bracelet
Post by recapt »
Cross-posting this from here: viewtopic.php?f=18&t=1983#p71172
Just received two of these single-pass adjustable straps from AliExpress (gray and green). I was curious to see whether they were still wearable when adjusted for my 6.25” wrist and I’m happy to say they are.
I think I finally found a strap I like on this Timex MK1, despite the different finishing between the case and strap hardware.
The quality seems pretty good considering the price (I paid $18.88 delivered for two straps). Hopefully they are durable. We’ll see. So far I’m very happy with the purchase.
Here's the link: https://a.aliexpress.com/_dXkZQOm
Now some pics!
househalfman
Post by househalfman »
Nodus TecTuff...
...and leather from Nodus still...
whoagorgeous
Post by whoagorgeous »
If anyone has experience with crafterblue strap, I could use some advice.
On this side of the strap, the bars do find the lug holes, however, doesn't fully "click" into a secure position.
A light tug and it'll pop right out.
Along with stratching the hell out of my lugs, I have tested two sets of spring bars with and without different straps and this problem is only presented on the "short" side of the crafterblue strap.
Any help would be appreciated.
Watch is a SLA021
(I've also emailed crafterblue but I didn't buy directly from them so we'll see what kinda response I'll be getting.)
Sussa
Post by Sussa »
Received a new batch from CNS today. The highlight so far is this 21mm NATO adapted to fit an Oceanus.
Working on a two-piece NATO too, but it didn't quite go as expected. I wanted to just make two small cuts and tuck in the middle fabric, but the nylon is too stiff. Not bad though.
Sussa wrote: Fri Aug 28, 2020 4:44 pm Received a new batch from CNS today. The highlight so far is this 21mm NATO adapted to fit an Oceanus.
Very nice! I'm not sure what you did there but that's the best looking aftermarket set-up I've seen on one of these.
Sussa
Post by Sussa »
yinzburgher wrote: Sat Aug 29, 2020 1:47 am
It was ridiculously easy. If you have a ruler and an Exacto knife, you're good to go. Here's an illustration showing what I did:
Screen Shot 2020-08-29 at 9.09.38 AM.png (12.03 KiB) Viewed 33329 times
The red dotted line represents the path of the lug pin. The green lines are where I cut. I started with very small cuts at the intersection of the path and extended them toward the case (important for a neat appearance) as needed to accommodate the center lug. Then it's a matter of weaving the pin and the strap to put it on. I used a lighter to melt the nylon and stop fraying at the cuts while the strap was attached so the holes wouldn't weld shut.
Is holding a lighter near your watch inadvisable? Probably! Did I burn myself trying to protect the watch from heat? Absolutely! In hindsight, I would suggest just running the pin through the holes while sealing and keeping the watch away from fire.
Stretch44
Post by Stretch44 »
cheddar
Post by cheddar »
This Veblenist navy cordovan strap came in today. Exactly what I was hoping for. I love cordovan straps.
tjcdas
Post by tjcdas »
coms
Looks great how did you overcome the collar issue to hold the pin in place?
I have the same watch the blue strap looks amazing!
Sussa
Post by Sussa »
tjcdas wrote: Wed Sep 02, 2020 9:33 pm
Surprisingly, the pin stays in place and I think the strap is providing enough friction. When worn, the part of the strap that goes over the pin should be pulling down, away from the watch head with a little force. Pair that with the pin being reasonably tight in the lugs anyway (that is, it doesn't just slide out with gravity if there's no strap) and it stays put. If I notice a pin getting a little too close to the outside of the lug, I give it a little nudge back in place.
It's worth noting that I mostly sit at a desk all day. Unless there's a particularly animated conference call, walking the dog and cooking dinner are the most vigorous activities this watch sees.
frogles
Post by frogles »
AndyS wrote: Tue Aug 04, 2020 6:30 pm SNE541 w stainless shroud and bracelet.jpeg
My SNE541 with new $10 Ali Express bracelet. A bit noisy as it doesn't have amazing tolerances, but to be honest it's not that different from some stock Seiko stuff. Also has a $35~ Ali Express stainless shroud.
Original look of the watch:
if you still like this bracelet, a link please
thank you
AndyS
Post by AndyS »
frogles wrote: Wed Sep 16, 2020 2:28 am
thank you
For the money, it's nice. I moved it over to a Momentum Flatline a couple of days ago. Here's the link.
(Dusty because I was doing a project around the house involving drywall :))
Flatline - Bracelet 03.jpg (42.5 KiB) Viewed 33260 times
Stretch44
Post by Stretch44 »
New strap from Aaron Bespoke. Really impressed.
Stretch44
Post by Stretch44 »
Two new straps for my Legend Diver. Shout out to [mention]cortman[/mention] for sending me the black CNS tropic. Thanks! The orange is a Dan Henry Tropic. Really dig the color combo.
cortman
Post by cortman »
Looks great [mention]Stretch44[/mention] ! Glad it's working for you.
