Tissot le locle from eBay seller everydaydealsince1997
Talk about your experience, good and bad, here.
chicharo
Post by chicharo »
Model t0064072203300
I compared the caseback from Tissot website and my watch. I can notice a difference on the serial number. Is my watch a replica?
Thanks for the help
images - 2020-04-04T232533.969.jpeg (55.04 KiB) Viewed 11219 times
Re: Tissot le locle from eBay seller everydaydealsince1997
First thing to consider is that the image from Tissot of the caseback is a render. So might not equate to how the caseback would look like in real life.
But if you do have concerns, I imagine you could contact Tissot with the information and they should be able to verify if that serial number is authentic.
I would guess yes, but if I would reach out to Tissot if it were me.
chicharo
Post by chicharo »
TheJohnP wrote: Sun Apr 05, 2020 5:09 pm First thing to consider is that the image from Tissot of the caseback is a render. So might not equate to how the caseback would look like in real life.
Thank you so much for your reply. Then, is a normal thing to find a watch with different serial number than the serial displayed on tissot website? Maybe was a stupid question, sorry.
Thank you for your help
Correct. The serial number is specific to each watch made.
There shouldn't be two watches of same model with same serial number.
tommy_boy
Post by tommy_boy »
Oddly, they're repping this watch.
I'd never buy one off of fleabay.
May be just me.
DogOnTime
Post by DogOnTime »
There are no reps of the 80-hour movements so you should be able to verify with that alone as the calibre-80's aren't sold outside of SWATCH-owned brands.
chicharo
Post by chicharo »
Nsjong wrote: Mon Apr 06, 2020 3:49 pm There are no reps of the 80-hour movements so you should be able to verify with that alone as the calibre-80's aren't sold outside of SWATCH-owned brands.
Thank you so much. Could you teach me to identify the movement?
chicharo wrote: Mon Apr 06, 2020 7:00 pm
Here's the model page for your watch from Tissot:
https://www.tissotwatches.com/en-en/sho ... 80-10.html
The movement is the caliber Powermatic 80.111
Which you can read more about here:
https://calibercorner.com/tissot-caliber-powermatic-80/
chicharo
Post by chicharo »
TheJohnP wrote: Mon Apr 06, 2020 7:10 pm
Thank you. I think i would need to open the watch :(
chicharo wrote: Mon Apr 06, 2020 7:35 pm
You probably shouldn't need to, if you have a local watchmakers, they can inspect it for you.
chicharo
Post by chicharo »
TheJohnP wrote: Mon Apr 06, 2020 7:38 pm
I'm trying to look through the caseback. Any particular signal or serial to search? Sorry, I'm very rookie on this topic
chicharo wrote: Mon Apr 06, 2020 7:44 pm
No worries. This is how we all learn.
It looks like from this photo, you should be able to see C07111 under the balance wheel.
Or it could be just outside/underneath the balance wheel.
Use a magnifying glass or loupe if you have one.
DogOnTime
Post by DogOnTime »
You can do one of 2 things:
- make sure the movement runs for ~80 hours
- check the balance wheel as the 80-hour movements do not have visible regulators
chicharo
Post by chicharo »
There is no number. Probably, it's a fake movement. Thank you for the help
chicharo wrote: Mon Apr 06, 2020 9:06 pm There is no number. Probably, it's a fake movement. Thank you for the help
Th number might be under this section of the caseback.
I think you should be fine.
