Chips Ahoy
Electric Avenues
LAByrinth
Circuit Path
Digital Directions
Sporkboy Makes Stuff
Re: Sporkboy Makes Stuff
Easy.
"The Circuit"
"The Circuit"
Circuitous board
A-maze-ing circuits
A-maze-ing circuits
Circuitous Route
File Path Not Found
Circuit Path Not Found
File Path Not Found
Wired for life
A-Mazing Tech
Follow Your Bits
Connected to the Future
Interoperable
Throughput
The walls inside
Plug and Play
Life Circuit
Logic Problem
A-Mazing Tech
Follow Your Bits
Interoperable
Throughput
The walls inside
Plug and Play
Life Circuit
Logic Problem
Thank you to everyone for your great ideas, they have been a huge help as I was spinning my wheels with this task.
Special thanks to [mention]Sussa[/mention] who broke through with the use of ‘circuitous’ which led me to the final name that was blessed by the art consultant :‘Circuit(ous) Path’.
Making a tool for measuring the the size of loose springbars. There is some variability in sizing, so it more gets you in the right neighborhood than anything else.
This is brilliant! Would you be willing to share the design file? I have a habit of leaving springbars on my desk rather than putting them back in the organized tray and this would be a big help.
Oh for sure. It is still under development, but I posted it on Thingiverse. It says it is only for @denormalize, but you can try it if you’d like. Feedback is appreciated.
https://www.thingiverse.com/thing:4781534
