Most watch case backs have a small tab, indent or seam in order to get a grip with a case back removal tool, which is typically single blade, or a knife.
Like this or similar.
Sometimes the typical single blade case back opener is very difficult to use or just doesn't work for the job. In addition there are snap off case backs without any indent or seam of any type to allow for a grip.
That's where this handy tool comes to the rescue. You can find it on Ebay for around $27 under deluxe snap off case back remover.
You position the watch dial down, adjust the lever with the springs the correct height to grip the watch case back keeping the handle parallel with the blade at the grip point on the case back. Turn the green wheel to close the base against the lever blade, very tight, so it doesn't slip and scratch the case back, and press the lever handle down. It works.
Video
https://www.google.com/search?q=how+to+ ... SP-pjACQ61
Snap off case back remover.
Re: Snap off case back remover.
That's a handy device!
I normally just used a rounded tip Xacto knife with pretty good results, but I can see how this may be better.
I bought it cause I had to open one of those case backs lacking any means to get a grip. Nothing I tried worked and I was starting to scratch it. Searching for a solution found this device, and I was surprised how well it worked. But I'll stick to the usual opener unless it's a difficult case, easier and faster.ManOnTime wrote:That's a handy device!
Not sure if this belongs in the tools thread, move if more appropriate.
Seems like a tool to me.PetWatch wrote: ↑Sun Oct 04, 2020 11:22 amI bought it cause I had to open one of those case backs lacking any means to get a grip. Nothing I tried worked and I was starting to scratch it. Searching for a solution found this device, and I was surprised how well it worked. But I'll stick to the usual opener unless it's a difficult case, easier and faster.ManOnTime wrote:That's a handy device!
Nice, thanks for sharing. Those pressure fit case backs can be tricky sometimes.
Another tool I’ve had great luck with is one of these little “pry” type openers. Pop casebacks right off that would never open with the typical case knife.
https://www.ebay.com/itm/324118089519
Mods, if it's a simple task please move this thread to the more appropriate Tools forum.
The bill is in the mail.
I’ve never had a problem getting them open, but I’ve ruined two cheap watches trying to get them back on.
