That dial is gorgeous.yinzburgher wrote:The watch you see below was announced just over a month ago but I never got around to posting it here and I don't believe anyone else did either. I like the dial and love a big date complication. The movement, using the Powermatic 80 or ETA C07.111 as it's base, is similar to that of the Mido Big Date watches introduced in 2018, except this one uses a Nivachron (titanium-based alloy) balance spring to resist magnetism.
LINK TO THE WATCH ON CERTINA'S SITE
MORE INFO ON THE SWATCH GROUP SITE
CERTINA ON INSTAGRAM
Details and Specifications
Model Name: Certina DS1 (Double Security) Big Date 60th Anniversary Special Edition
Ref: C029.426.11.091.60
Case: 41mm diameter x 9mm height, 316L stainless steel
Dial: dégradé green dial with sunburst finish
Crystal: Sapphire crystal w/ anti-reflective coating on underside
Water Resistance: 100m (10 bar)
Movement: ETA Powermatic 80.651, automatic
Functions: Hours, minutes, seconds, big date
Frequency: 28,800 vph (4 Hz)
Power Reserve: 80h
Strap: Stainless steel (Milanese) with butterfly clasp
Price: €925 (euros)
MONOCHROME WATCHES
WATCHONISTA
ORACLE OF TIME
2019 New and Upcoming Releases!
Re: 2019 New and Upcoming Releases!
This watch is begging for a metal bracelet.yinzburgher wrote: ↑Wed Sep 25, 2019 10:40 pm Magrette Timepieces, the New Zealand based microbrand is releasing their first GMT, the Moana Pacific Waterman GMT. It will be available in both stainless steel and CuSn8 bronze cases with a choice of a blue ceramic or red and blue aluminum bezel. Pre-orders have started with a price of $815 inclusive of shipping.
LINK TO THE PRE-ORDER
MAGRETTE ON INSTAGRAM
Available with choice of blue ceramic or blue+red aluminum bezel insert, both fully-lumed for legibility of GMT time in low light.
MOVEMENT: Swiss Made ETA Caliber 2893-2 GMT automatic
CASE DIMENSIONS: 42mm excluding crown, 50.7mm lug-to-lug, 14.5mm tall, 22mm lug width
CASE FINISH: Brushed stainless steel or CuSn8 bronze, each with stainless steel engraved case back
BEZEL: Engraved ceramic or two-tone aluminum, both fully lumed with Swiss Super-LumiNova® C3 green
CROWN: Screw down crown, signed with Magrette shield
CRYSTAL: Sapphire (box style), anti-reflective coating
DIAL, HANDS & BEZEL: Contrasting Swiss Super-LumiNova® BGW9 blue (local time) and C3 green (GMT time)
WATER-RESISTANCE: 500m/1650ft water resistance. Viton® gasket used on case back
STRAPS: Vintage minimal-stitch leather and blue TROPIC™-style rubber, each with signed buckle
LIMITED: 150 pieces per case initial issue*
Pre-order Price: $780.00 (plus $35.00 shipping). Regular price will be $890.00.
Deposit of $380.00 for the Moana Pacific Waterman GMT is required to confirm order.
We will be in contact with you again when the balance of $400.00 USD plus $35.00 shipping is due.
Note: Free shipping within New Zealand and $35.00 International.
*Future editions may be released pending demand.
WRITE-UP FROM A BLOG TO WATCH
Looks like going out of business. The last watch from MWW coming in November. It's a 38mm field watch.No more details than that.
Facebook page here https://www.facebook.com/mww802/
pgcity wrote: ↑Sat Sep 28, 2019 7:43 pm Looks like going out of business. The last watch from MWW coming in November. It's a 38mm field watch.No more details than that.
For some reason getting a SARB033/SARB035 vibe with that case, except for the drilled lugs of course.
Wonder if it's their Iconik 5?
The iconik series ended with iconik 4.
Is his last watch an explorer dial in a SARB-inspired case with drilled lugs and box sapphire?
Nodus is teasing a new watch, the Duality, that launches this Friday 10/4. They say in the comments that it will be 40mm x 13mm (with domed crystal) and 48mm lug-to-lug. Appears to be a super compressor.
More teaser pics on their IG account.
New one from Oak & Oscar, the Ashland collaboration with Wilson. They released it in the right month.
In the past year or two, Seiko has released two Prospex MarineMaster 300 models (although without the MM designation), the SLA021J1 and the SLA019J1. While it has been known for some time that there are two more on the way, there was never any confirmation or release date announced by Seiko. Both in blue, the SLA027 Zimbe Limited Edition is expected to be a production of 428 pieces while the SLA023J1 is expected to be non-limited. In recent days, the SLA023J1 is showing up on more and more sites as in stock and available for purchase.
Expected Details and Specifications
Case: Monocoque; Stainless Steel w/ Diashield coating
Bezel: Zirconia ceramic unidirectional
Diameter: 44.3mm
Thickness: 15.4mm
Movement: Automatic with manual winding capacity
Caliber: 8L35
Accuracy: +15 to -10 seconds per day
Power Reserve: Approx. 50 hours
Crystal: Sapphire w/ AR coating on underside
Lume: Lumibrite on hands and indexs
Water Resistance: 300m w/ screw-down crown
Bracelet: Stainless Steel w/ Diver's extension
Diameter: 44.3mm
Thickness: 15.4mm
Caliber: 8L35
Unfortunately I don't have much information or sources to cite for this, but there has been a hint/leak/speculation that a Presage re-issue of Seiko's 1964 Tokyo Olympic Chronograph may be in the works. An original is pictured below.
That would be cool. I've thought about buying one of these many times, especially the grey dial. I'm a sucker for a grey dial.yinzburgher wrote: ↑Wed Oct 02, 2019 11:24 am Unfortunately I don't have much information or sources to cite for this, but there has been a hint/leak/speculation that a Presage re-issue of Seiko's 1964 Tokyo Olympic Chronograph may be in the works. An original is pictured below.
I expect this would coincide with the 2020 summer games in Toyko.
- AndroidIsAwesome
Damnit I want thisyinzburgher wrote:In the past year or two, Seiko has released two Prospex MarineMaster 300 models (although without the MM designation), the SLA021J1 and the SLA019J1. While it has been known for some time that there are two more on the way, there was never any confirmation or release date announced by Seiko. Both in blue, the SLA027 Zimbe Limited Edition is expected to be a production of 428 pieces while the SLA023J1 is expected to be non-limited. In recent days, the SLA023J1 is showing up on more and more sites as in stock and available for purchase.
Diameter: 44.3mm
Thickness: 15.4mm
Caliber: 8L35
another teaser. looks like bauhaus font?pgcity wrote: ↑Sat Sep 28, 2019 7:43 pm Looks like going out of business. The last watch from MWW coming in November. It's a 38mm field watch.No more details than that.
No more info so far but this popped up on Worn & Wound's IG account. Hopefully the final product will have the inner military hour track aligned with the aperture on the hour hand.
Don't recall anyone mentioning these before, but Watch Wonderland out of Singapore has a couple of exclusive Snoopy watches.
Watch Wonderland and Undone come together in their first collaboration, paying tribute to Peanuts with the officially-licensed "Snoopy's Surf Shack" collection. Both variants are limited editions of 100 pieces.
Undone Aqua x Peanuts x Watch Wonderland "Beagle of the Deep" Exclusive Edition
Priced at $608.26
Local (Singapore) price w/GST: S$899
https://wonderland.watch/products/undon ... ve-edition
- Movement: Automatic with Hacking and Hand-winding
- Caliber: Japanese Seiko NH35
- Power Reserve: 41 hours
- Dial: Matte white dial with Snoopy 'Beagle of the Deep' motif, aged lume indicators and gold hands
- Lume: BGW9 Superluminova on bezel insert, vintage lume on indices and hands
- Crystal: Domed sapphire crystal with anti-reflective coating
- Case Material: Stainless steel
- Bezel: 120-click unidirectional with K1 glass full-lume insert
- Caseback: Steel screw-down with glass exhibition window and Peanuts x Watch Wonderland printed comic image
- Water Resistance: 100 metres
- Crown: Screw-down crown
- Case Size: 43.5mm
- Lug-to-Lug: 52mm
- Case Thickness: 16mm
- Strap: White rubber strap
- Buckle: Stainless steel tang
- Strap Specification: 22mm
- Comes with black Undone watch travel case
Undone Aqua x Peanuts x Watch Wonderland "Surfs Up" Exclusive Edition
Priced at $608.26
- Dial: Matte blue dial with Snoopy 'Surf's Up' motif, 3D character surfboard indicators and white skeletonized hands
- Bezel: 120-click unidirectional with K1 glass navy blue insert
- Case Size: 43.5mm
- Lug-to-Lug: 52mm
- Strap: Black canvas strap with Cordura fabric underside and quick-release springbars
Priced at $608.26
- Case Size: 43.5mm
- Lug-to-Lug: 52mm
Priced at $608.26
- Case Size: 43.5mm
- Lug-to-Lug: 52mm
