I think I used to wear one with this module. After you press and hold the bottom right button until it starts to flash, what happens when you press the bottom left button to cycle through? After all the time settings it should continue to cycle through the date settings. And then as each setting blinks you can hit the top right button to set it to the desired day, month, etc.rich_in_the_lou wrote: ↑Sun Aug 25, 2019 10:04 amI just got one - One small problem - I would like it to display the date & day on the LCD as in the pic BUT I can't figure out how to set the date. I found instructions at Katmai Instructions but either I don't understand thrm or they don't work. Can someone tell me how to set the date?
>>>< The Ultimate Timex Thread ><<<
Re: >>>< The Ultimate Timex Thread ><<<
- rich_in_the_lou
Thanks so much - The LCD on my watch now readw 8-25 SU
Just what I wanted
Just what I wanted
That one is high on my list of next Timex to buy. Your pics are making the case stronger.
... What time is it?
I'd love to find a new condition stainless version of that for under $70.
The lowest I've seen it is $100 ... I got lucky as I got it as a trade for a cheap Eco Drive.
I assume this means the Timex Q will be in stock again on 9/13 in the Timex site shop. If you're interested, you may want to sign up now for their email list now to get your 15% discount code.
Edit: This second post is a bit more clear.
https://www.timex.com/browse/collection ... x-reissue/
The Timex Q will be back in stock again on Tuesday 9/17. Try using the promo code WELCOME20. It may still work.yinzburgher wrote: ↑Thu Sep 12, 2019 11:59 am I assume this means the Timex Q will be in stock again on 9/13 in the Timex site shop. If you're interested, you may want to sign up now for their email list now to get your 15% discount code.
https://www.timex.com/q-timex-reissue-3 ... Watch.html
MoT... check walmart.com
I'm only seeing the PVD version.
