First tipped off via discord by @captinsano443
Lima watches Meca Revolt collaboration with seconde/seconde sold out of the initial 30 piece run.
However, through Jan 31st, you can preorder a copy. I believe that is the only window in which this will be available.
https://limawatch.com/product/pre-order ... rrency=USD
Preorder price is $320
Estimated delivery is June 2024
"U No Brando" is a watch collaboration project with seconde/seconde in reference to Marlon Brando's iconic GMT Ref. No. 1675.
- Diameter: 38mm
- Lug to Lug: 45.6mm
- Thickness: 11mm / 12.8mm with Crystal
- Lug Width: 20mm
- Movement: Miyota 82S0 Automatic with Hacking Second
- Case: 316 L Stainless Steel
- Bezels: Two Interchangeable FIXED Bezels
- Crystal: Double Dome Sapphire Crystal
- Crown: Screw Down Crown
- Lume: Japan Luminova
- Strap: Tropic Style Rubber Band with Quick Release
- Bracelet: Bonklip Bracelet with Quick Release
- Water Resistant: 200m
- Warranty: 12 months
PREORDER: Brand Direct: Lima Watches - Meca Revolt x seconde/seconde "U no Brando"
