PREORDER: Brand Direct: Hz Watches - HZ.01 Collection
Hz Watches, out of Melbourne, have opened preorders for their debut collection, the HZ.01.
https://hzwatches.com/collections/32-768-hz-collection
48 hour launch price is $170 - SOLD THROUGH
Preorder price is $235
Expected delivery is April 2024
The HZ.01 started as a personal project to build myself the perfect everyday watch. In doing so, I defined four key principles that made up the perfect everyday watch, and designed the HZ.01 around these principles: Comfort - Versatility - Accuracy - Durability
The HZ.01 is available in three colorways - Blue, Green, and Burgundy
Specifications
- Diameter: 38.5mm
- Height: 9.85mm
- Lug to Lug: 46mm
- Lug Width: 20mm
- Weight: 45 grams (including attached strap and titanium buckle)
- Case material: Titanium case
- Crystal: Sapphire crystal with anti-reflective coating
- Crown: Push in crown, signed with HZ logo (new update post production samples)
- Lume: Swiss superluminova BGW9
- Movement: Swiss Ronda 507 quartz movement with day/date function
- Dial: 2 layer construction with sunburst dial, and raised concentric circle sector dial
Re: PREORDER: Brand Direct: Hz Watches - HZ.01 Collection
Handsome watches, good specs and I thing "Hz" is a brilliant name for a quartz watch.
