Post your mods here!
Re: Post your mods here!
ManOnTime wrote:
Sporkboy wrote: Wed Apr 10, 2019 2:51 pm [IMG]https://uploads.tapatalk-cdn.com/201904 ... 0e6053.jpg[/IMG]
Two Timex casebacks. One I added a bit of enamel paint, squeegeed off the excess, let dry, did some clean up and hit it with some matte acrylic. The other one is stock for comparison.
Casebacks don’t get much attention, but given a little paint, they can really pop.
This also shows the underside of a Timex that I stripped down to the brass.
I know these aren’t you ordinary mods, but I have fun with them.
That's really cool!
Thank you. It was something that I hadn’t seen done in the modding scene outside of filling in crown and bezel details with crayon. That is a technique that has been around a really long time and I use it on lots of my tools at work.
The Timex watch backs of this type really are kind of nice, so I thought I would see what I could do with a little paint. It took me a while to figure out that I needed to remove the paint while it was wet, like you were spreading ink to make a print, but I got there.
It also helps if you give the surface a good cleaning to remove and gunk from the engraving and then a wash of rubbing alcohol before applying the paint.
Sporkboy wrote:
FTE wrote:
Sporkboy wrote: Wed Apr 10, 2019 2:47 pm
Then brushed it shall be...
[IMG]https://uploads.tapatalk-cdn.com/201904 ... b4c87b.jpg[/IMG]
Quite an improvement and easier to keep lookin nice.
I did mess up the retention spring, so it now spins more or less freely. I will need to try to fix that tomorrow. Then that will be it as far as easy, external mods go. Though I might paint the caseback as it is pretty interesting.
Looks good. What did you use to do the brushing? Brillo pad?
I used 2 grades of scrubbing pads-corse(green) and medium(white).
I am not sure if this is an international standard though. There are also red pads, which are supposedly finer than the white, but I haven’t found them. I also think it looks good with the medium level scrubbing pads.
In the states, the common brand is scotch-brite. I am not sure what Brillo makes, but I always think of the corse scouring pads that are imbedded with soap. I wouldn’t want to use one of those on a watch.
I will take some pictures of what I have later.
For these I mounted the piece on an electric screwdriver, which makes it easy to get the bezel looking nice. Getting around the crown required more work.
When brushing, you want to only brush in one direction otherwise you get diagonal scratches that look poor. You can always polish out the brushing later if you don’t like the look, though that has never been an issue for me.
If you do this on a plated watch, you have to be very careful not to go through to the base metal. Stainless steel cases are the best for brushing.
[IMG]https://uploads.tapatalk-cdn.com/201904 ... d7d699.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... 34f567.jpg[/IMG]
I went a little too far in cleaning off the Amphibia case back, but it looks a bit better now.
[IMG]https://uploads.tapatalk-cdn.com/201904 ... 237a05.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... a37530.jpg[/IMG]
There are the before and after pictures. Now for the process!
[IMG]https://uploads.tapatalk-cdn.com/201904 ... d7ea7c.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... 62c0a0.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... 343cdd.jpg[/IMG]
Area around the caseback was masked, though it was removed as it got in the way of scraping off the paint...
Paint half scraped off.
[IMG]https://uploads.tapatalk-cdn.com/201904 ... 2b4eed.jpg[/IMG]
All paint scraped off with a fake credit card.
[IMG]https://uploads.tapatalk-cdn.com/201904 ... ccd677.jpg[/IMG]
Cleaned up with q-tips and rubbing alcohol.
[IMG]https://uploads.tapatalk-cdn.com/201904 ... b33de3.jpg[/IMG]
A little cleanup to do, but I call it a win.
Update: cleaned it up and I am calling this back done. I don’t think the matte acrylic is required, so I am going to see how it holds up as is.
[IMG]https://uploads.tapatalk-cdn.com/201904 ... 8ef0e9.jpg[/IMG]
[IMG]https://uploads.tapatalk-cdn.com/201904 ... 2817f7.jpg[/IMG]
Invicta 8926. Dial repainted (needs redoing), watch and bracelet brushed, glide lock style clasp added.
[IMG]https://uploads.tapatalk-cdn.com/201904 ... ffff33.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... 63ecdb.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... 870fdf.jpg[/IMG]
Sporkboy wrote: Thu Apr 11, 2019 2:53 pm Invicta 8926. Dial repainted (needs redoing), watch and bracelet brushed, glide lock style clasp added.
Looks pretty good. Where did you get the clasp?
AliExpress. Got the wrong size and had to find and file to get it to fit.
Bbrou33
Post by Bbrou33 »
Sporkboy wrote:Invicta 8926. Dial repainted (needs redoing), watch and bracelet brushed, glide lock style clasp added.
Looks really good. Love the orange
Sent from my SM-G935U using Tapatalk
Insta me: bbrou33
Thanks, I believe that the color is ‘safety orange’ from the hardware store.
Alright boys! I finally got the last piece for my mod in the mail today (bezel insert) and got it all together. This is only my second mod, so cut me some slack. This one involved a lot of firsts for me. First time dealing with the crazy Invicta bezel setup, first time removing an engraving and repolishing and first time removing a cyclops(there is still some residue to get rid of). Also, second time changing hands (F YOUUUUU seconds hand and wasting 45 minutes of my life!!!!!)
Here are the specs:
-Invicta 8926 (generously gifted to me by(WUS) WPAC member eDantes to help feed my addiction without buying anything)
-Bezel made by Dave Murphy of Murphy manufacturing (really helpful guy and great products. There are like 3 or 4 different bezel setups for 8926's from the factory, and he helped me determine which one I had as well as directing me to videos he made to aid removal and installation)
-Dagaz dial and hand set
-Bezel insert from ewatchparts on Etsy (not the highest of quality, but for $13 I ain't complaining)
-Removed the Invicta engraving from the case and sanded and polished (could have done better here, next time. . .)
-Removed the cyclops
All in all, I am very happy with the end result. After reinstalling the bracelet, the stupid folded end links are rattling, so I have to fix that now. Without any further delay, I present to you the Polar Coke-Splorer!!!
[IMG]https://uploads.tapatalk-cdn.com/201904 ... 75053d.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... 14ac52.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... c06a0b.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/201904 ... df0bd1.jpg[/IMG]
Bbrou33
Post by Bbrou33 »
Dub Rubb wrote:Alright boys! I finally got the last piece for my mod in the mail today (bezel insert) and got it all together. This is only my second mod, so cut me some slack. This one involved a lot of firsts for me. First time dealing with the crazy Invicta bezel setup, first time removing an engraving and repolishing and first time removing a cyclops(there is still some residue to get rid of). Also, second time changing hands (F YOUUUUU seconds hand and wasting 45 minutes of my life!!!!!)
Here are the specs:
Wow man. That looks really really good. I'd give it a like but Tapatalk doesn't let me.
Love the dial with that coke bezel.
I do agree with you about Murphy. Here's a great guy to work with and very helpful.
I will be getting my esslinger supplies tomorrow meaning I'll be cursing in Saturday or Sunday when replacing the hands on mine. Hopefully by Sunday evening I'll have pics of my modded 8927
Insta me: bbrou33
Here are the specs:
Just go for it man! You might get lucky too! The first time I removed and reinstalled hands took me like 2 minutes. Then I realized it was pure luck. With some patience and a steady hand you will get there. Just let me know if you need some advice (I probably can't help much, but I will try!)
Also, the best piece of advice I picked up for the seconds hand (you shouldn't have trouble with hours or minutes, just make sure the movement has wound down and set them at 12:00) is that while it may look like the seconds hand has the male end going into the female end, it works just the same as the other hands. Meaning there is a post on the movement that goes into the hole of the seconds hand. This is where magnification (and luck!) Is key.
Regarding hand setting.
-Make sure that you set the watch to the date switch just be for you set the hands. Pull the crown out to lock the movement and then proceed. Otherwise the date will switch over at some random time (like 6:45 as mine is doing now).
-Attach the seconds hand to a toothpick with rodico or similar product.
-If your dial can handle rodico without smudging (i.e.: not glossy) or you have a protector down, then you can muse the rodico to tack the seconds hand in place while you press it down.
-Look at the seconds hand from the side when placing it. This is way easier than from above as you can see what is going on.
Here are the specs:
That mod looks really sharp. I still need to grind the logo off my case. Any tips?
If you don’t need the old dial/hands, I would love to have them. The posts could be broken off, that would make it easy to mail. I have some ideas for painting and luming that I would like to try that may ruin the dial.
If you want to hang onto the parts, that’s cool. Just thought I would ask in case they were headed to the bin.
Bbrou33
Post by Bbrou33 »
Here are the specs:
Thanks for all the advice guys!
Spork, chances are I won't be keeping them so I can ship them off to you. I'll let you know this weekend
Insta me: bbrou33
