Cheap but good shark mesh?
baldrick
Post by baldrick »
Hi, gang,
I fancy trying shark mesh on a couple of my divers. However, I'm not sure if I will love it, so I don't want to spend a fortune on a gamble.
Can anyone recommend a reasonably priced source of shark mesh bracelets that are also of decent (enough) quality?
I'm thinking around the USD 50 or lower mark, and can then go higher if I like the look and want better quality.
If that's completely unrealistic, what's the ballpark?
Thanks in advance!
Re: Cheap but good shark mesh?
baldrick wrote: Thu Apr 08, 2021 1:52 pm Hi, gang,
Thanks in advance!
Just outside your range, but maybe check out WatchGecko. They offer well made bracelets.
Here's a shark mesh they have for about $66. But they're is also 10% off code that works, brining it to down to $59.
https://www.watchgecko.com/shark-mesh-watch-strap
baldrick
Post by baldrick »
Thanks both - just what I was after. I'll test the amazon ones and then move up to the gecko if it works.
[emoji106]
I own the second amazon one and can confirm good quality...but note that unlike Matt’s first link, it must be cut to be resized. There are no removable links.
tommy_boy
Post by tommy_boy »
https://www.ebay.com/itm/20mm-22mm-24mm ... 2862534391
As a shark mesh enthusiast, I'll chime in.
I have at least one from this seller. I also have spare 20mm links (and maybe 22mm) that I am happy to send out at N/C to my larger-wristed brethren.
