On a whim, I purchased a two watch winder box made by Heiden from an auction site. I just assumed (you know what that means...) that it would also take batteries. Well, it doesn't of course and the AC adapter I see on their web site doesn't look compatible with the Prestige line. I have contacted their support to get some info but was wondering if anyone here knows the voltage, current, and whether the inner conductor is positive or negative.
TIA.
Q
Heiden Prestige Watch Winder
- Has thanked: 2209 times
- Been thanked: 691 times
Re: Heiden Prestige Watch Winder
Well, just as an update, I found some battery pack substitutes (all are sold out because it's so old) that say Heiden Prestige and Boxy compatible. It looks like it takes 4 D batteries, 2x2. So I am going to guess it's 3V/.5A or somewhere around there. Not sure whether the inner is positve or negative. I guess I'm going to have to risk it...
Here is a Boxy adapter with the specs conveniently blurred out:
https://www.ebay.com/itm/Heiden-Prestig ... 664?_ul=IL
And the Battery version
https://watchwinderstation.com/products ... ttery-pack
- Has thanked: 46868 times
- Been thanked: 35261 times
Keep us posted how it works out!
Well, bad news and good news. I found a variable output AC adapter I had lying around and tried it at the estimated 3V. Only one watch winder moved and the other didn't I thought the motor was burned out or the rubber drive band had broken. I found this very good video on how to disassemble a watch winder that looks exactly like mine (except his is a 4 watch winder). Evidently, Heiden must have made them for Brookstone
I followed the video and got the metal plate out. Bad news is, it looks like my rubber bands were still AOK. Then I read somewhere that someone tried upping their voltage and it worked. I switched mine up from 3 to 4.5 and magically the second winder started working. Sigh. It's a bear getting that plate out and trying to get it in the felt is getting damaged. Oh well...At least it's a learning experience.
