Zenith Cal.2572 Hi-Beat Automatic 9ct 1977
PS: This watch is listed on behalf of our trusted users at valueyourwatch.com. If you have any questions about the seller, do not hesitate to contact us at info@valueyourwatch.com. Our sellers are verified sellers with a strong reputation.
The asking Price will be $2,340 payment chosen by the seller. In general, you can pay by Credit Card, Wire, PayPal, Cash or others.
For more questions Tel. +447515949250 email: alan@vintagegoldwatches.com
Connect with me on instagram
Get 3% discount to pay by wire transfer
Feel free to contact us to see more watches at www.vintagewatchcentre.com or www.vintagegoldwatches.com
For inquiries please reach out to alan@vintagegoldwatches.com or john@vintagegoldwatches.com
Zenith
Zenith is one of the oldest watch manufacturers, est.1865 and one of only a handful which has always produced its own movements. The company has an almost unparalleled record of technical achievements and notably in 1929, Zenith won world renown at Kew Observatory (England), when a Zenith wristwatch won first prize for an accuracy of better than 0.6 seconds per day. During the late 1940s and throughout the 1950s, Zenith held the lead in producing the most commercially successful and technically advanced, chronograph wristwatches. Later, Zenith became the first in 1969, to develop a high-frequency automatic integrated column-wheel chronograph powered by the legendary El Primero movement beating at 36,000 vibrations per hour. This obsession with precision, as well as this constant quest for technical innovation, has been duly rewarded; the Manufacture has been awarded 2,333 chronometry prizes as well as eight medals, making it the most titled brand in the field of precision. The company has also provided a huge number of movements to many other manufacturers for their more technically advanced watches, including even Rolex for their Daytona Chronograph.
Description
The 1960s and ’70s saw Zenith produce some of the greatest watch movements available from any manufacturer, for example, its El-Primero which from a technical standpoint, watch movements were incredibly advanced. The watch we have here is an excellent example, having a superb Swiss made 9ct case and a 28,800 beats per hour, hi-beat automatic movement. Introduced in 1972, this made Zenith the first company to introduce a commercially successful hi-beat automatic movement.
The Dial
This Silver ‘Starburst’ dial with gold and black inlaid batons and matching original ‘stick’ hands is in the classic 1960s, slightly high-tech style. On point, the date position at 4:30 hours suggests the watch was an advanced, or should we say an avant-garde style, which was so on trend at the time. Zenith adopted the 4:30 hrs date position during this period and this has since become a Zenith trademark. It is actually a very sensible spot since as one rotates the wrist to view the date, the 4:30 through to 6 is the first portion of the dial to reveal itself. This dial is very stylish and reminiscent of the Mondaine SSB classic dial design adopted for use by the Swiss Railway.
The most notable feature of this dial is its complete originality. The dial has not been restored or retouched in any way. Even more remarkably it is in top condition and shows no signs of ageing visible to the naked eye. Only very close up, under high magnification can some of the slightest signs of scratching and some very light spots be found which is remarkable for a 40 year old watch and indicates the watch has been well cared for and seen little real use.
The Movement
The Zenith Calibre 2572 PC movement specification is also quite special, beating at 28,800 beats per hour, rather than the semi-hi-beat at 21,600, or the more usual 18,000 or 19,800. When one listens to this movement ticking, one can really hear this is a hi-beat movement racing. Generally speaking the higher the beats per hour, the higher the accuracy of the movement, all other factors remaining the same. This movement is also known as the ‘8 beat’ because it beats at 8 beats per second. The example we see here, with a date function, is one of the first of this model produced and this movement was used in Zenith’s top of the range automatics, between 1972 and 1975.
The movement has just been thoroughly overhauled and serviced by our vintage specialist watchmaker. This means fully dismantling the watch and movement, ultrasonic cleaning of all parts, inspection to the critical surfaces under high magnification and replacement as required with genuine new original parts, then careful reassembly and oiling, using all the correct lubricants to manufacturer’s specification before final testing and calibration. This watch is therefore now running perfectly having been calibrated and timed at +8 seconds per day! This is outstanding for any watch of this age and has been confirmed using our electronic Timegrapher. Although this is a Hi-Beat movement, the power reserve is still very high at 44 hours when fully wound. The watch movement is signed Zenith, Swiss Made and carries the Calibre number 2572PC.
The Watch Case
The heavy, Shackman made Tonneau case is of a solid two-piece construction, in 9ct yellow gold. Tonneau shaped cases became highly popular in the 1970s and this excellent example was made by David Shackman & Sons, of Chesham, Bucks, U.K. Shackman were very high-quality case-makers and one of two English case-makers used by Zenith, the other being Dennison & Co. of Birmingham.
The case is stylish, sturdy and highly impressive and measures 34mm, excluding the Zenith signed crown. The press fit case-back is of full thickness and has never been engraved. It is tightly fitting and presses back with a very reassuring ‘pop’.
The case has been cleaned, carefully inspected and then lightly hand-polished by our case-maker and shows every sign it has been well cared for and lightly used. The case has not been overpolished as all the edge definition of the case has been nicely retained. There are no scratches, dings or other marks visible to the naked eye.
Inside the case all is correct and as expected, signed D.S.&S (David Shackman & Sons Ltd) along with London U.K. 9ct Hallmarks and the reference numbers 35555 and 2215/1.
Our standard advice applies: vintage watches should be kept clean and dry at all times.
The Strap and Buckle
The watch is fitted with a high quality dark brown leather strap with a plain gold-plated buckle. However, if a different colour or style of strap is preferred, please let us know and we will do our best to oblige, free of charge. We carry tan, conker, dark brown burgundy and black straps in stock, in plain padded leather, alligator, crocodile or lizard skin.
The Box and Papers
Although there are no original papers with this watch, the reference numbers, markings, signatures and hallmarks are all correct, dating the watch to circa 1977.
Detailed particulars will be included with our purchase receipt for your interest and security. A separate insurance valuation for the replacement value of this watch will be provided at the time of sale along with our unique ‘Lifetime Authenticity Guarantee’ which states: “If this watch proves to be anything less than 100% genuine, authentic and original, a full refund will be given at any time”.
The watch also comes complete with the high quality presentation box as shown in the photographs.
In Conclusion
This is a very impressive and very rare vintage Zenith automatic wristwatch, which is ready to wear and very practical for everyday use. If treated with care, this watch will make an excellent investment or heirloom piece. Zenith has always benefitted from a first class reputation for the superb quality of their watch movements and just as in the case of Longines, which have been undervalued in the past, this is beginning to show in the way Zenith watches are increasing in value.
A word on our prices – We always try our hardest to acquire the very highest quality watches we can find, before we restore them to the highest possible standards. We then offer our watches at the fairest prices we can, taking into account our pre and post sales care and service. This approach means we will never be the cheapest, but nor will we be the most expensive. Indeed there are some well-known stores in West London which are highly successful charging between two to three times the price you see here. We therefore consider our prices to be fair, given the quality of watches we have to offer.
We are happy to accept payment via PayPal as this is the quickest method of payment. However, if you would like to pay by UK cheque or by bank transfer, we will be pleased to assist you with this and pass on a 3% saving in transaction charges to you.
Please check the import duties and any taxes your government may apply, these are different for each country and unfortunately out of our control.
We understand there may be some ‘loopholes’ that may help you avoid these charges, however attempting to use these could impact our ongoing ability to serve our growing international customer base.
For those that happen to visit the UK on occasion we are of course more than happy to store your watch until we can meet you in our offices in Kensington, London and hand your watch directly to you there.
*Please note – our 12 months’ warranty is only included if the list price is paid.
Please note, we welcome part exchanges and if you have a watch or small collection for sale, please contact us as we will be happy to discuss this.
We will be happy to Service, Repair or Restore your watch, all at ‘sensible’ prices. Please see here.
If you have any questions, please call us on 020 7727 7095 or if calling from overseas on +44 207 727 7095.
We will be happy to answer any questions and offer advice about this or any of our watches listed for sale. If you would like some general advice regarding any aspect of vintage watches, including buying, selling, or collecting, we will also be very happy to hear from you. We await your call!
Finally, please enjoy some time spent viewing our other fine vintage gold watches!
[url=https://valueyourwatch.com/store/www-vi ... tches-com/] More Pictures: Value Your Watch[/ur
FS: Zenith Cal.2572 Hi-Beat Automatic 9ct 1977
- ValueYourWatch.com
- Brand Rep
Honza Hroch / info@valueyourwatch.com / No Sellers Fees, No Buyers Fees
Buy and Sell Luxury Watches at Value Your Watch Marketplace
- Brand Rep
Re: FS: Zenith Cal.2572 Hi-Beat Automatic 9ct 1977
UP
