SUCCESSFUL : Brand Direct: Isotope Watches - GMT 0º Collection
Isotope Watches will be launching their latest collection, the GMT 0º on Sunday, Jan 31st at at 3pm GMT = 10am EST.
They will be taking preorders directly through their site and foregoing Kickstarter.
https://isotopewatches.com/products/iso ... ro-degrees
Regular version of the GMT 0ºwill be priced at $967.20
Limited Edition version of the GMT 0º will be priced at $1,117.04
Isotope will be offering a timed and tiered discount strategy based on when you back the project:
- 30% off - For 48h only. From 31 January to 02 February, starting at 3pm GMT (U.K. Time). Insert code on checkout: GMT30
- 25% off - From 02 to 12 February, starting at 3pm GMT (U.K. Time) and for 10 days only. Insert code on checkout: GMT25
- 20% off - From 12 to 22 February, starting at 3pm GMT (U.K. Time) and for 10 days only. Insert code on checkout: GMT20
- 15% off - From 22 February to 31 May, starting at 3pm GMT (U.K. Time). Insert code on checkout: GMT15
For backers during first 48 hours, regular version will be $677.04 and limited edition will be $781.93
Estimated delivery is June 2021
Modern GMT watches have until now tended to have a similar layout, generally using an extra hand to indicate the time in a second time-zone; it is the absence of this hand that distinguishes our watch from many other GMTs.
The entirely bespoke Isotope GMT 0º replaces the function of the extra GMT hand with a distinctive dial design, featuring an Isotope Lacrima (teardrop) shaped cut out and the combination of a date dot and a GMT disc, which has never been used together before on the same dial. The Lacrima shape is now part of the DNA of Isotope, present on all dials and in various details of all our watches.
Clarity is important, so the second time zone is shown using the colored indicator on the central disc. The date is in turn indicated by a coloured dot visible through one of 31 holes drilled into the multi-layered dial. Finally, the local time can be read conventionally, on the hour indices also cut into the dial. Each element clearly separated from each other, so minimizing the opportunity to misread information.
The GMT 0º will be available in four regular colorways - white, black, blue, and olive green.
The Limited Edition versions of 49 units each, will be available in olive green DLC and ruby.
- Brushed case, 316L stainless steel/Black Diamond-like Carbon
- Case diameter 41.5mm x 39.5mm (44.7mm with lugs)
- Height 14.2mm
- Exhibition screwed case back with the world’s major cities time-zone
- Anti-reflective domed crystal sapphire
- Single Screw-down crown at 3 o’clock
- Hands applied with Super-LumiNova®
- 24mm strap tapered to 22mm
- Matching Buckle
- Water-resistance 200m / 20 ATM / 656 Ft
Movement is Swiss made customized Swisstech S24-45 (3 years warranty):
- Automatic, self-winding
- Power reserve 40 hours
- 28 Jewels, 28800A/h
- Accuracy -12/+12 s/day
- Customized finishing, date and rotor
Re: PREORDER: Brand Direct: Isotope Watches - GMT 0º Collection **LAUNCHING Sun 1/31 at 3pm GMT**
Isotope is offering a special 32% off for the first 24 hours to folks who signed up for their newsletter with code - 2N654X.
This Saturday, 30 January, and for 24 hours only, pre-order your Isotope GMT 0º with an exclusive 32% VIP discount.
The offer starts at 3pm GMT (U.K. Time) and expires Sunday at 3pm GMT.
This will bring the regular version to around $657.70
And the limited edition version to around $759.59
The Isotope Watches GMT 0º preorder is LIVE!
Preorder at this link - https://isotopewatches.com/products/iso ... ro-degrees
Here's a video that Jose from Isotope posted to introduce the model and show how the GMT and date discs work.
From an email from José at Isotope:
Pre-orders end Sunday, August 8th.
15% off of any GMT 0º with code GMT15.
Offers still available until the 8th (and what's in the box):
- Bespoke Cordura strap.
- Bespoke leather strap.
- Bespoke Quick-Release Metal bracelet on any Stainless Steel version.
- Black Seat Belt Nato with Black PVD finish, exclusive for the Limited Edition Olive Green Black DLC.
- Surprise gift on the Limited Edition Ruby.
- Bespoke Isotope tool (spring bar remover and screwdriver).
- Your preferred GMT 0º version.
- Swiss Made movement with three years warranty.
After pre-orders, prices will have a slight increase.
Isotope GMT 0º - delivery timeline:
- Quality Control and watch parts selection: from the 2nd to the 9th of August.
- Assembling of 1st batch: from the 9th to the 20th of August
- Quality Control of assembled watches: from the 11th to the 25th of August
- Shipping: starts on the 15th of August.
