DuFrane Watches out of Austin have opened a VIP pre-sale for the latest model, the Deep Eddy dive watch.
The first 100 pieces are currently under assembly, regulation and final testing with DuFrane striving for delivery in the late-September timeframe.
Please be aware, no additional discounts will be offered on the pre-sale.
https://www.dufranewatches.com/products ... dive-watch
Preorder price with a custom silicone strap is $499
Preorder price with silicone strap, stainless bracelet, and leather strap is $599
Estimated delivery for the first 100 pieces is September 2021
Inspired by the oldest spring-fed swimming pool in Texas (1936), Deep Eddy pool is as much a staple in an Austin summer as sunshine and heat. What was originally an area along the Colorado River where locals would cool off in the natural spring area, it was transformed into an actual swimming pool, while still maintaining its original sprig-fed source. Legend has it, there was a rather large bolder near the swimming area and as water flowed by, it created a small eddy. The case back engraving is our rendition of how that may have looked.
The two dial colors signify the aquamarine color of the pool, and the earthy brown grasses that surround the area.
The two colorways are Lagoon or Dune, along with the option of date or no-date.
Movement- Swiss Sellita SW200-1 Élaboré grade
Regulated Accuracy- +/- 8 sec/day
Case Diameter- 42mm
Bezel Diameter- 42mm
Case Material- Marine Grade 316L Steel satin brushed with polished highlight chamfering on case, bezel & lugs
Case Back- Screw Down, 2X Gasket, Marine Grade 316L Steel
Crown- 7mm 2X Gasket, Screw Down
Thickness- 12mm
Thickness w/Crystal- 13.1mm
Lug-to-Lug- 47.6mm
Lug Width- 22mm
Bezel- Engraved Aluminum w/C3 Lume
Crystal- Double Domed Sapphire, 2X AR Coating
Hour and Minute Hand- Diamond Cut Polished Steel, Lume Filled
Second Hand- Diamond Cut Orange Lume Reverse Lollipop
Indices- Applied indices recessed into angled chapter ring
Lume- Swiss SuperLumiNova C3
Case Weight- 82 grams
Case Weight w/Bracelet- 132 grams
Water Resistance- 20ATM (656ft/200m)
12-month international warranty
Assembled and Tested in America (Austin to be exact)
PREORDER: Brand Direct: DuFrane Watches - Deep Eddy Dive Watch
Re: PREORDER: Brand Direct: DuFrane Watches - Deep Eddy Dive Watch
As much as I love a date function, that teal no-date is fire. Also, the dune color is really unique.
DuFrane has introduced the last colorway for the Deep Eddy, Snow which is available for preorder.
All specs remain the same, except the the movement.
The Deep Eddy Snow are all produced using the robust Swiss Ronda R150 mechanical automatic movement.
DuFrane will regulate each piece to run +/- 8 secs per day.
Also the Snow appears to only come with a date option.
Only 50 total pieces will be available.
https://www.dufranewatches.com/products/deep-eddy-snow
Preorder price, which includes a custom black silicone strap is $499
Adding the Adventure Accessory Pack, which includes a SEL stainless bracelet and leather strap is an extra $100
Or adding a Milanese Mesh Bracelet is an extra $36
Shipping will begin on Monday the 14th of February.
