PREORDER: Brand Direct: Isotope Watches - Hydrium and HydriumX Limited Editions
On Saturday, September 25th at Noon UK time, Isotope will start accepting pre-orders for the Limited Edition Hydrium Burnt Tangerine, with a high-visibility dial, and the HydriumX "Will Return", inspired by the most iconic clock door sign. They'll only be making only 100 of each. They are offering preorder discounts with codes for a limited time.
The expected delivery date is March 2022.
Isotope Hydrium Burt Tangerine
Preorder price with code HydriumBTangerine is £435 (roughly $595)
List price will be £544 (roughly $744)
https://isotopewatches.com/products/hyd ... ttangerine
Isotope HydriumX "Will Return" Edition
Preorder with code HydriumWillReturnis £450 (roughly $615)
List price will be £563 (roughly $770)
https://isotopewatches.com/products/hydriumwillreturn
Technical Specifications
- Movement: Miyota 9039
- Case: Micro-blasted, 316L stainless steel
- Diameter: 40mm
- Lug to lug: 48mm
- Lug width: 22mm
- Height: 11.3mm (14.8mm with domed Sapphire Crystal)
- Caseback: Hydrium = Exclusive Stainless steel screw-down case back or HydriumX = Exhibition screw-down case back
- Bezel: Uni-directional with 120 clicks
- Crystal: Anti-reflective sapphire
- Crown: Screw-down at 3 o’clock
- Dial: Hydrium = Tangerine two-layered sandwich dial or HydriumX = White glossy dial filled with Swiss Super-LumiNova®
- Hands: Hydrium = Isotope "i" hands and indexes with Super-LumiNova® or HydriumX = Isotope Lacrima hands with Swiss Super-LumiNova®
- Water-resistance: 300m / 30 atm / 1000 ft
- Strap: Quick-release Cordura and FKM straps with signed micro-blasted Steel Buckle
