PREORDER: Brand Direct: Werenbach - Soyuz 2 B.T.O. Superlative Collection
Werenbach have just launched their updated version of their B.T.O. (Built To Order) customizable Soyuz 2 Superlative collection.
The material comes from Soyuz MS-09, which was launched on 6 JUNE, 2018, 13:01 UTC.
https://www.werenbach.ch/en/shop-tag/bto/
For the next 72 hours, use coupon code Community2021 to take 20% off the preorder price.
With code Community2021 pricing ranges from $1805.68 - $2,539.50
Regular pricing ranges from $2,257.10 - $3,174.37
Estimated delivery is March/April 2022
There are 150 pieces available during this preorder with five different custom colorway options.
B.T.O. I - Material from inside the Booster Tank in the original aluminum surface.
B.T.O. II - Material from outside the Booster Tank in an olive-grey, unmodified surface.
B.T.O. III - Material from outside the Booster Cladding in an orange, unmodified surface.
B.T.O. IV - Material from the Fairing in a white, unmodified surface.
B.T.O. VI - Material from the Fairing in a white-red, unmodified surface.
In the configurator, you'll first choose your dial from the available options:
Next choose your case material.
Steel is included in price. PVD is an extra $164.90. For a case made with melted down Soyuz rocket material is an extra $463.79
Then choose your "Spaceborn" case badge.
Steel is included. PVD is an extra $30.92. For one made from white Soyuz fairing materials is an extra $154.60
Choose your hands.
Silver hands are included. Black hands are an extra $10.30
Finally choose your strap.
Textile straps are included. Leather straps are an extra $10.30. Rubber strap is an extra $20.61. Stainless bracelet is an extra $256.63. Stainless PVD bracelet is an extra $288.58.
- Movement: Soprod Newton, Top Grade
- Dial Material: Unmodified Rocket Material
- Case Material: Stainless Steel or Melted Down Soyuz Rocket Material
- Diameter: 41mm
- Height: 9.7mm
- Lug Width: 20mm
- Crystal: Sapphire
- Caseback Crystal: Hardened K1 Mineral
- Lume: SLN X1 GL C2
- Water Resistance: 10 ATM
