Maen Watches have opened preorders for their upgraded Hudson 38 Automatic, the MK4.
https://www.maenwatches.com/pages/hudso ... collection
Preorder price for EU is €599 (roughly $678)
Preorder price outside EU is €479.20 (roughly $542)
All Korean customers will receive FTA documentation
In addition, you can add a NATO or tropic rubber strap as an upgrade.
Estimated delivery is mid-April 2022
MK4 Upgrades:
- The case for the Hudson MK4 has been completely re-designed from scratch.
- The watch will be equipped with a brand new Ceramic Bezel and improved X1 Superluminova. The new deeper engraved bezel structure now has a mixed polished and brushed finish assuring better grip. The bezel mechanism also has been improved for a smoother rotation.
- The case construction has been improved now giving the watch a 30ATM rating. The newly designed crown allows for better and more solid screw down motion.
- The dial has also been upgraded to a more textured finish and the indicators have now X1 Superluminova for better performance. The Jet Black Date and our new Carbon Grey Date model will even have Red X1 Superluminova accents on the hour and second hand!
- The bracelet has also been improved and will feature more micro adjustments and will have solid (not stamped) polished mid links on the end piece.
The Hudson 38 MK4 is available in four variants - Jet Black date or no-date, Carbon Grey, and Midnight blue
- MOVEMENT: Ronda R-150 Swiss Made Automatic Movement
- DIAMETER: 38mm
- THICKNESS: 12mm Including glass and caseback
- LUG TO LUG HEIGHT: 46mm
- LUG WIDTH: 20mm
- WEIGHT: 129Gr
- CASEBACK: Screw-down
- CROWN: 7mm screw-down crown
- MATERIAL: 316L Surgical grade stainless steel
- BEZEL: 120 click unidirectional ceramic bezel
- CRYSTAL: Domed sapphire crystal + AR coating
- LUME: X1 Superluminova
- BRACELET: Satin brushed stainless steel bracelet with polished mid links
- STRAP WIDTH: 20mm narrowed down to 16mm
- CLASP: 316L deployant clasp with pushers
- WATER RESISTANCE: Waterproof to 30ATM
PREORDER: Brand Direct: Maen Watches - Hudson 38 MK4 Automatic Collection
- Has thanked: 46882 times
- Been thanked: 35282 times
