Phantasos Watches, sister brand to ZŪM Watches and Angles Watches, have launched their first Kickstarter for their debut collection, the Triclops: A Three Armed Rotating Hour Watch.
Though this is their first campaign, they are fully funded with 340% over goal.
Launch Day pricing was $598 SOLD OUT
Super Early Bird pricing is $618
Early Bird pricing is $648
Choice of limited edition number pricing is $698
Regular pricing will be $980
Bracelet or extra straps are available as an upgrade.
Estimated delivery is June 2022
Three-armed wandering hour watches are exclusive and rare and usually very expensive...even on Kickstarter. And virtually all others employ three flat sapphire or metal disks with hour numbers represented on each disk. The Triclops goes a different direction: the hours are now on each facet of a 4-sided rectangular cylinder (an "hourlisk") that like a long blink turns to its new hour as the hourlisk starts its travel across the minute register above. It is more "active" and far less confusing than reading a 2 dimensional disk with all 4 numbers of each disk visible. The three "eyes" spin around our Triclops giving the wearer a bold and striking statement. This watch is a game-changer.
The Triclops is available in 5 colorways - Viridian, Steel, Nightwalker, Royal Blue, Pitch Black
Case
- Movement: Miyota 90S5 with Rotating Hour Module
- Case: 316L stainless steel or 316L stainless steel with DLC Black
- Diameter: 42mm
- Height: 13.5mm
- Crystal: Top double-dome sapphire crystal with antireflective coating.
- Dial: Double layer dial with Swiss Super-LumiNova® pigment that is white in daylight and, when properly charged, glows blue-green in the dark.
- Caseback: Exhibition sapphire crystal
- Crown: Push-pull
- Water Resistance: 5 ATM (50m)
- Strap: 24-20mm Italian vegetable tanned leather hand-stitched with solid 316L stainless-steel buckle.
SUCCESSFUL : Kickstarter: Phantasos Watches - Triclops, A Three Armed Rotating Hour Watch
Re: SUCCESSFUL : Kickstarter: Phantasos Watches - Triclops, A Three Armed Rotating Hour Watch
447 backers pledged $317,322 to help bring this project to life.
