Etien Watches out of Singapore are taking preorders for their absolutely gorgeous T01 collection.
https://etien.watch/collections/all
Preorder price is $1,388
Estimated delivery is May 2022
The pieces were all handmade specially implemented through a process called Flinqué Enamel. This technique was a renowned practice by Peter Carl Faberge.
The dial is crafted with CNC engine-turned guilloche pattern and covered with multiple layers of translucent colored enamel. The result is a beautiful guilloche dial with enamel watch.
The T01 is available in three colorways - Blue, Green, or Salmon
- Limited Edition: 25 pieces in each colorway
- Movement: ETA 2824-2
- Diameter: 40mm
- Lug to Lug: 46mm
- Thickness: 10mm
- Case, Caseback and Crown Material: 316L stainless steel
- Crystal: Sapphire
- Strap: Alran Chevre Goat with lining Zematt Calfskin
- Water Resistance: 3 ATM
- Warranty: 2 years international
PREORDER: Brand Direct: Etien Watches - T01 Collection
Re: PREORDER: Brand Direct: Etien Watches - T01 Collection
why did they have to spoil it with the minute track on chapter ring? ambitious pricing for an unknown(to me) brand.
Fully agree both points. Should at least be elabore grade with a display caseback.
Don’t you need the minute track in order to set it?
I agree it's pretty. I also think it looks like a Magic Eye.
