Originally tipped off by @IKEEPGOODTIME in the official MoT Discord chat.
Zentier Watches, out of Hong Kong, have recently opened preorders for their latest collection, the Reverence.
https://zentier.com/collections/reverence
Preorder pricing for Salmon and Spectre variants are $549
Preorder pricing for Aventurine Bleu is $649
Estimated delivery is end of August 2022
REVERENCE - A sign of honour, respect or deep adoration - felt or shown.
The idea which inspired the Reverence collection originated from the very definition of the name itself. To understand, learn and respect the legacy and the classic elements invented by the greatest watch makers of all time. To create something that is timeless and at the same time refreshingly modern. Pursuing and achieving a fine balance between tradition and reinvention.
The collection is available in three colorways and limited to 100 pieces for each - Salmon, Spectre, and Aventurine Bleu.
Each watch will come with two leather straps and a two watch travel case.
- Movement: ST-1700 Hand wound, mechanical movement with small seconds sub-dial.
- Dial: Natural blue Aventurine stone dial or double layered brass dial decorated with stamped guilloche patterns.
- Case diameter: 38mm (excl. crown)
- Case height: 9mm
- Lug to lug: 45mm
- Strap width: 20mm/18mm
- Case: 316L High grade stainless steel
- Crystal: Flat sapphire crystal with anti-reflective coating
- Strap material: Natural suede leather.
- Buckle: 316L Stainless steel pin buckle.
- Water Resistance: 5 ATM
- Warranty: 12 Months warranty from date of purchase.
PREORDER: Brand Direct: Zentier Watches - Reverence Collection
Re: PREORDER: Brand Direct: Zentier Watches - Reverence Collection
These are all good looking, but I think I like Spectre the most.
Samesies.
- New Member
Heeeeyyyyyyyy, the blue watch it's just .... wow
