Loresum was founded and designed by Jason Chan, who had a prior brand JW Watch and was a designer for Behrens Original.
This is the second collection for Loresum and second Kickstarter, their first campaign was fully funded.
Heads up, these are not typical Kickstarter priced. But then these have a unique in-house regulator module and 7 layers of exposed gears.
48 Hour Early Backer pricing is around $1,159
Super Early Bird pricing is around $1,195
Early Bird pricing is around $1,232
Kickstarter pricing is around $1,280
Regular pricing will be about $2,283
Estimated delivery is April 2023
The LS02 comes with a module like no other. For this particular design, Chan developed a whole new regulator module to go on top of the movement. Regulators are complicated and difficult to make. The market is dominated by top watch brands and only a handful excel at it. The LS02 contains an original regulator module based on the Miyota 9015 with modifications made according to the golden ratio. We placed the hour dial at the top, seconds in the middle and minutes on the bottom in a perfect, vertical alignment. They are filled with Swiss Super-LumiNova® BGW9 to ensure maximum visibility even in the dark. A rotating gear on the left serves as a day and night indicator and the dial on the opposite side shows the date.
The LS02 is available in two colorways - Silver and Rose Gold Plated
SUCCESSFUL : Kickstarter: Loresum Watches - LS02 The Mechanical ‘Golden Ratio’ Designer Watch
Re: SUCCESSFUL : Kickstarter: Loresum Watches - LS02 The Mechanical ‘Golden Ratio’ Designer Watch
32 backers pledged £25,276 to help bring this project to life.
