Crepas Watches have returned to Kickstarter for their latest collection, the Inmare 300m dive watch.
This is their sixth official campaign and it has already fully funded, as have their previous campaigns.
Super Early Bird pricing is around $697
Early Bird pricing is around $718
Late Bird pricing is around $740
Kickstarter pricing is around $804
Regular pricing will be about $855
Estimated delivery is September 2023
How do you read the time on this watch?
- It is very simple. We have replaced the hour hand with a disc under the dial.
- On the dial you can see a window with a triangle at the lower part. The triangle points to the time which is shown by a number between two bars.
How is the decompression time scale interpreted?
All numbers on the dial are grouped into three groups:
- The minutes in increments of 5 in a circle. Starting at minute 5 and ending at minute 55. These numbers are located on the outside of the dial.
- The dive meters in four levels: dives to 25 meters, 30, 35 and up to 40 meters deep. These depths are inside a box below the 12 o'clock mark.
- Four concentric circles with numbers above them. These numbers represent the decompression time as a function of the dive depth and the time spent on the dive.
The Crepas Inmare is available in three colorways - Steel, Black with White, or Black Four Color.
• MOVEMENT: ETA 2824-2
• DIAMETER: 42mm
• LUG TO LUG: 50mm
• THICKNESS: 13.10mm with box sapphire
• CRYSTAL: Antireflective box sapphire. 37mm and 2mm thick
• CROWN: Signed screw down crown. 7mm
• CASE BACK: Screw down case back cover.
• FINISH: Brushed or polished stainless steel.
• HANDS: Vintage bluish diving hands style with Swiss Superluminova
• LUME: Swiss Superluminova BGW9
• WATER RESISTANCE: 30ATM = 300m
PREORDER: Kickstarter: Crepas Watches - Inmare 300m Dive Watch
- Has thanked: 46870 times
- Been thanked: 35262 times
