Does anyone know the dial size for the Invicta 8926?
I’m going to buy some parts (case, dial, hands and an NH35) from aliexpress and take a SWAG at putting together a watch. Years ago I bought a $50 invicta to mod and never got around to playing with it. It wasn’t the 8926 ( it was the scallop bezel with the coke insert, but if I recall it was the same size as the 8926). Anyway, since I am ordering parts for the build I figured I would throw in an extra dial to the order and finally(maybe) mod the Invicta.
I did a quick Google search, but figured one of you guys would know this. I recall there was a VERY LONG thread over on WUS about mods but the dial size just isn’t jumping out at me.
8926 dial size
- CigarCity
- Has thanked: 4132 times
- Been thanked: 1546 times
- MoT
- Site Admin
- Has thanked: 13423 times
- Been thanked: 30144 times
Re: 8926 dial size
It's been a few years since I put one together, but if I recall it is 28.5mm, and remember to get a 4:00 crown one so you don't have to mess around with clipping feet and using dial dots.
- Rabirnie
- Has thanked: 24647 times
- Been thanked: 7484 times
- Rabirnie
Re: 8926 dial size
I think you are getting this confused with the SKX and 4:00 crown for the dial. The Invicta would need a 3:00 crown, unless I've somehow confused the two.
- Dub Rubb
- Has thanked: 24685 times
- Been thanked: 10738 times
Re: 8926 dial size
I am way late to the party here, but can confirm that the stock dial size is 28.5mm, however, the 8926 can accommodate at least a 29mm dial.
That said, if you are going for a build from scratch, there is a couple really great case options on AliX and ebay that NH movements drop right into, and you dont have to worry about removing the Invicta tramp stamp.
Here is the vintage 5513 case with friction bezel, drilled lugs, your choice of bezel insert and plexi- https://www.ebay.com/itm/Stainless-Stee ... 2749.l2649
There is also a new 5 digit case with sapphire on Ali that I could find if interested.
