Help me decide
Elkins45
Help me decide
Post by Elkins45 »
I’ve been wanting a meteorite dial watch for a while now. Zelos occasionally offers them but the natural dials sell out within hours and I don’t want one that is painted over. I’m thinking about rolling the dice on a Proxima and these are some of the options I’m considering:
https://wrwatches.com/collections/watch ... 3225121901
Plusses: stainless case, Seiko movement.
Minuses: 44mm
https://wrwatches.com/collections/watch ... -meteorite
Plusses: 42mm, Seiko movement.
Minuses: aluminum case?
https://wrwatches.com/collections/proxi ... 9316828269
Plusses: 42mm, stainless case, not another diver
Minuses: Chinese PT 5000 clone movement
Size wise I like the 42mm models but one is aluminum and the other has a Chinese clone movement. I’m leaning toward giving the aluminum case a try but the practical part of me says get the 44mm because 2mm isn’t that much of a difference.
Your thoughts?
Re: Help me decide
There is nothing wrong with the PT5000, I actually opted for that movement in my incoming Ipose.
That being said, and since I'm cheap and seeing that they are all quite similar, I'd end up going with whatever is the least expensive.
The aluminum cased one would be fun to try since it's a material not commonly used.
